Looking To Buy Sti Ecu Any Thoughts???
THANKS FOR YOUR HELP GUYS! I AM LOOKING TO BUY A STI ECU FROM JAPAN, JDM 2002 GCB OF A 280HP STI, WONDERING IF IT WOULD DO ME ANY GOOD, IF NOT RECOMMEND ME ANOTHER LIKE UTEC, PLEASE GIVE ME FEEDBACK...THANKS AHEAD OF TIME
Car Info: '03 PSM Sedan
i'd go with an aftermarket, programmable ECU instead. the STi runs differant fuel injectors that with a higher flow rate, so you'll definitely have problems there. also. i seem to recall that that JDM STis run variable valve timing, so the ECU probably wouldn't like your stock US spec cams. there are just too mant differances between the two motors to make it a straight swap, and to see performance gains. i'd suggest that you take a look at the EcuTek units. i can't imagine that they're that much more than an STi black box. just my $.02
dcmomentum
05-31-2005 06:45 AM
