View Poll Results: I found this information to be...
...informative and I have a better understanding about intakes.
100.00%
...not convincing, so I'm still installing an intake.
0%
...confusing, so I'll reserve judgement on intakes.
0%
Voters: 10. You may not vote on this poll
Links to info on cold-air intakes and the MAF sensor
Old 05-13-2004 | 12:44 AM
Wingless Wonder's Avatar
Doesn't matter if it's a short ram or CAI - anything that changes the airflow in the vicinity of the MAF (mass airflow sensor) will affect tuning in a negative way. Leave it stock unless you plan to spend the bucks for an hour of dyno tuning for little or no gain just to smooth out the torque curve.
MAF mis-readings as explained by BAN SUVS.
This is an alternative method of correcting what the aftermarket intake does to MAF metering posted by EcuTek in the UK.
Josh of Cobb Tuning on aftermarket intakes.
Topic again explained by azscoobie (Clark) and confirmed by Shiv Pathak of Vishnu Performance.
It may be a different story if you're upgrading to a big turbo (bigger than the usual VF30/34 on an EJ20) or a front-mount intercooler which necessitates the use of an aftermarket intake.
Old 05-13-2004 | 04:27 PM
RussB's Avatar
Car Info: $200,000 sports car
could you make a thread similar to this explaining the details of MBC's, PTFB, and the differences between Open Loop and Closed Loop fueling?
Subi_Bojo
01-23-2014 02:26 PM
rubberbulletz
05-25-2009 02:55 PM
Maverick7
07-17-2003 10:16 AM
jriggs
03-07-2003 01:12 PM
Quick Reply: Links to info on cold-air intakes and the MAF sensor
