install a/f gauge with out Oxygen Sensor Kit??
does any one know a way to install a/f gauge with out buying the auto meter Oxygen Sensor Kit?
well, i read about the problem of WRX o2 sensor, the per cat sensor is 5v and after cat is 1v, so if i installed on the after cat sensor it is not going to read right! If i install on the per cat one it is alos not going to read right! So does any one know how to install a a/f gauge with out spend alot of $$$ because the o2 sensor kit cost $99.99
You can install it, but without the proper sending unit, it won't read correctly. And if you aren't using a wideband sensor, it won't read correctly outside of a narrow range of ratios.
Location: Flying on the H1 w/ 75 psi of compression on all 4 cyl
Tru that man a A/F ratio gauge is just there took look pretty in your unless you want to spend 400 bucks on a wide band 02 sensor.
imprezapilot
01-06-2004 10:22 PM
