IAT sensor (on 2.5 non-turbo?)
Location: EBAIC- Wondering if I should have taken the blue pill...
So is there any way to "re-tap" the MAF somewhere else, possibly after the IC, to make tuning that much easier? Or would that mess with things too much and not be plausible?
iClub Silver Vendor
Car Info: MY05RS, MY70914, and MY10VT1300CS
Naw I've just been reading up on little mods you can do to increase HP at WOT (wide open throttle) and one of em was a IAT mod. From what I've read if you put a simple resistor in the connector that goes TO the IAT sensor it will advance your timing and give ya a tad more HP at WOT. But i was just wondering. I'm really hoping to hear from some guys that do tuning to see if this is even possible. But if all else fails i'l just go get a PerfectPower ECU or something.
IAT Sensor
So it true, In the new 2.5L's the IAT is built into the MAF Sensor, But are there any Subaru Techs out there that know with of the 5 wires feeding into the MAF are for the IAT
Cheers
Cheers
iClub Silver Vendor
Car Info: 2005 LGT wagon
Cheers
Cheers
Look at the connector as it fits onto the MAF.
The wire 2nd from the left ( should be) the wire you quest for.
Old School
Car Info: '99 RBP GM6
Matt, that iat mod doesn't work...
i think your sensor was in your airbox thing you removed anyways for the Injen.
you want power? go 4-1 headers, run 91 oct 76 gas, and get a perfect power and take that **** to mike.
-Gagan
-Gagan
SIR_WRX
02-24-2006 01:53 AM
ASpec818
12-11-2005 06:54 PM
