How much psi
Car Info: 2004 WRX in WR Blue
To answer your question in full, with a proper boost conrtol you can push a constant 16.5 psi right below fuel cut-off (17 psi). Some people will claim that a stock WRX with BC (boost control) can handle up to 18 psi with no affects. I own an Apexi AVC-R BC and love it. You can control boost in every gear to fit the curve. Electronic over manual no doubt. Just for kicks I think the stock WRX runs 9.5 psi in 1-3rd and 14.5 in 4th and 5th. Not 100% on that though.
Originally Posted by truWRXtacy
i got a ecutek from vishnu, and it runs 16psi (or so they say)
i have an 03 wrx and i my boost spools up to 14psi and go down to 13.5psi from 1st to 5th gears. i'm stock everything except for the deleted snorkus. i have an autometer boost gauge, if that matters they all should the same tho.
chris
chris
