how to install apex avcr
I bought last week , and i have problems to intall it .I dont where is the best place to put the solenoid and sensro.If somebody have a manual "how to intall the avcr in the wrx 2002" please send me e-mail: mleta29@hotmail.com
thanks so much , Marc
Re: how to install apex avcr
Try this link out:
http://www.apexi-usa.com/productdocu...savcr_wire.pdf
Just check to see which engine you have and the model year. Hope this helps.
I just installed my apex in last night.I hooked my 2 grounds up to the fire wall.grind some of the paint off the firewall and put both wires in a stake con and screw it to the firewall or where ever the wires end up at.You need to get a Manuel showing the wrx ecu wiring diagram to get rpm and speed and tps wires.
your lucky the link that was posted shows your hook up to you ecu my car wasn't in the apex book.just hook it up like it shows you got it easy.
here is the link to your hook up again.http://www.apexi-usa.com/pdfWiring/2.pdf
Vinces25RS
10-07-2004 08:34 PM
