Greddy Profec-B Spec II HELP
Just installed this baby. Looks awesome....mounted right above the steering wheel column. I took out the "P" switch.
BUT...how the heck do you set up this thing???
Lo/Hi boost is not working right....I'm getting higher boost in the Lo setting eventhough the Hi setting is set higher. The directions that came w/this are worth ****ake
I have a Unichip Stg 1......was set at 1.1 bar (~16psi) w/the MBC
The problem w/this is that the settings is based on percentage....it's not making sense. I set it @ 100% and that goes way up to about 1.5 bar at part throttle in 1st gear!!! When I turn it down......I can't even get up to stock boost (~14.5psi)!!
What's up
Another problem is.....My BOV isn't blowin off!! My guess is I have to many T's in that area.....It's like a LA freeway in the BOV area. I also have a mechanical boost gauge in that area.....
I know I'm just yappin away but HELP !!!!!!
What's up
this might help: http://www.2gnt.com/nuke/modules.php...wcontent&id=34
i have a 03 wrx with a full turbo back, and bov. i just put the spec 2 in aswell, i put mine in right next to the cup holder in the dash. enough small talk, here are the pirameters i put in to get about 11.5 psi in lo and 15.5 psi in high. note... turn the last boost mode on so you can see what boost your are running, and my settings are in psi not kapi or whatever
lo- gain 6%, set gain 105, waste gate 28%
hi- gain 8%, set gain 145, waste gate 44%
p.s. i dont thing my lo boost is set very well, i think the gain % is off, if any one else has pirameters send them along
keep truckin'... good stuff
dgp2003wrx
04-30-2005 07:31 PM
ctdragon
08-31-2003 02:11 AM
NRTmotorsports
08-04-2003 05:31 PM
