electric supercharger
Old 04-07-2003 | 10:28 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Your kidding right? There is no way in hell that an electric motor can sustain the CFM levels needed to create a forced induction application.
Stop shopping on ebay for parts
Old 04-07-2003 | 10:42 PM
mmboost's Avatar
Hehehe, did you see the picture going around that had a Mustang with an electric Toro leaf blower motor on the intake?
jason
Old 04-07-2003 | 11:12 PM
Re: no
Originally posted by Johnny Rocks
no why?
because it's frikkin' hilarious!
Old 04-08-2003 | 09:04 AM
Northrn Snowman's Avatar
Car Info: WRX SW 02
Actually there are electric assist turbochargers under development:
There is an electric motor/generator on the turbo shaft of the turbocharger that is used to spin it at low engine rpm's. It is supposed to eliminate turbo lag. Pb is it requires a lot of juice. This is solved with bigger batteries and a motor/generator that control maximum boost by braking the turbo and generating electricity.
Still experimental, though.
If you want I can try to find some articles on it.
Old 04-08-2003 | 07:28 PM
Kay95's Avatar
electric supercharger/turbocharger could be done with a large enough blower of air but the problem is power and room requirements.
Old 04-09-2003 | 03:57 PM
mmboost's Avatar
It should be called a "turbocharger assist" not an "assist turbocharger" because it "charges" nothing. This doesn't qualify at all as an electric turbocharger. It does not compress the intake. It keeps a turbo spooled to a certain RPM nothing more.
If Johnny Rocks had mentioned one of these, we probably woulda been like "ooooh neat idea"
jason
Old 04-09-2003 | 03:58 PM
mmboost's Avatar
A battery that pushes like 2000 watts
jason
Old 04-09-2003 | 06:34 PM
enigma's Avatar
Why an Electric Supercharger Will NOT work
You could create an electric supercharger.
but why?
An electric supercharger claims advantage over a traditional suypercharger due to the fact that it does not run on a belt drawing power from your car. Instead it runs on electricity.
One Question:From where does it get its electricity?
Answer:Same place everything else does...the alternator...whichs runs off a belt and robs power.
So, by the time you install an alternator large enough to push a SC, you really haven't accomplished anything. Actually, you have lost since their is never 100% efficiency in energy transfer.
Sound reasonable?
Old 04-22-2003 | 07:56 AM
Car Info: WRX SW 02
Reply to Dr Moreau
That's exactly how it is supposed to work.
I have read too that they might use the electric motor to control over boost by slowing the turbo down by generating electricity:
To read more see the section about electric drive turbo's in:
http://www.autofieldguide.com/articles/050103.html
Is Less More?
By Christopher A. Sawyer, Executive Editor
By the way, what kind of animal are you?
rugmonkey
05-22-2008 06:24 PM
hutman4
03-23-2007 09:21 AM
knight1833
07-05-2005 07:09 PM
I3eXa
Wanted
04-23-2003 08:43 PM
