Dianogstic code reader
Hey
My check engine light came on recently and I don't know why.
My freind said that him and his father used a piece of wire to connect two contacts on the ECU dainogsitc port to get a flash code through a led light.
I've been reading about the subaru "flash codes" but everything that I've read you need the specail tool for it. but it still uses a led light on the ECU.
Does anyone know a trick such as using a piece of wire for subarus?
hYpE-R-29
11-05-2004 06:08 PM
