cobb stage 2 problem
Car Info: 2016 WRX
i have an 02 WRX and recently purchased a Cobb accessport v.1. I "installed" the stage 2 map with 91 gas map and have noticed that when i push the car, it hesitates, the RPM indicator kicks up fast (above 3k RPM) but the car doesnt pull. After about a couple seconds I noticed the indicator goes back down and then the car begins to pull. What could be causing this problem?
I have a Perrin pulley, Helix catted DP, STI up pipe, and Perrin Turbo Inlet Hose installed with about 89K miles.
Thanks in advance for any help
Car Info: 02' wrb wrx w/ RGII
i picked up the exedy clutch/fly wheel combo from gruppe-s was $650 shipped to HI..i'm sure it's a lil cheaper for you mainland guys..anyways installin it was simple and luvin the feel..since your down there re-place the main seal (it's only 15 bucks)..you mite also wanna look into the ss clutch line i heard good things about it..pedal feel is great and i'm luvin it..
srbaugust
15
06-02-2013 02:02 AM
enzo350
11-03-2006 07:49 AM
strider327
16
10-17-2006 09:32 PM
casualsurfer
05-03-2004 03:24 PM
