cobb engine check light on, pls help! P0244
Old 06-08-2007 | 07:58 PM
lburrrna's Avatar
Cool cobb engine check light on, pls help! P0244
hey guys,
Wat does this code means: P0244 Turbo Wastegate Selenoid "A" Range/Performance
Mods:
fp18g
STI TMIC
Stock injectors
invidia catted downpipe
HKS Hi-power catback
RA sti tranny 5 speed
Currently milage: 16,xxx
i was driving normally on the freeway and decided to WOT in 5th gear. i felt like a hesitation (i guessing a fuel cut) CEL came on with P0244
P2044: Turbo Wastegate Selenoid "A" Range/Performance
thanks!
Old 06-10-2007 | 09:48 AM
LunarHonour's Avatar
Car Info: STI 2006 White Stage 666
You over boosted and hit fuel cut (the fuel to the engine got cut off because the boost went higher then the limit set in the ECU). Your wastegate probably was not able to evacuate enough exhaust to prevent this.
Old 06-10-2007 | 07:24 PM
lburrrna's Avatar
Smile
ok, i believe is the weather. it get cold here and foggy here in california, right now its fine. the CEL went out by itself! anybody experience this? i have no more CEL!
Old 06-12-2007 | 09:24 AM
testes1010's Avatar
it is completely normal for 06-07 WRX to get boost creep......especially in colder weather & in 5th gear at low load(ie: low rpm, WOT)...
Old 06-20-2007 | 04:25 PM
Lorry's Avatar
CELs usually go away if the problem has been resolved. Some of them require a number of successful stop/start cycles. If you google, you can find reference sheets describing the CEL #s and how they are set/cleared.
Bolt21
05-02-2010 12:47 AM
tanz1983
02-07-2007 09:55 PM
tanz1983
01-16-2007 08:41 AM
MaVz
12-27-2005 02:13 PM
silver satin
09-10-2004 08:09 AM
