Cobb AP .. which map fixes dp wastegate problem for STi?
Old 12-30-2005 | 10:06 PM
sjice's Avatar
Car Info: '13 BRZ - SWP
My STi has the usual boost problem after I installed my helix downpipe. When i hit a certain MPH or psi the engine freaks out and shuts down the acceleration. I am gettin a Accessport this Saturday, and I'm wondering what map I should use? I'm going to install a california map, but I was wondering which one to do..
Stage 2 LWG Cal Stage 2 mapping for California fuel with lower Wastegate Duty Cycle mapping to eliminate boost spiking experienced with some owners. 1.10
or
Stage 2 HWG Cal Stage 2 mapping for California fuel with with higher Wastegate Duty Cycle mapping for those unable to hit the boost targets. 1.10 [base map]
Old 12-30-2005 | 10:37 PM
mcowger's Avatar
Car Info: 2009 A3 2.0T quattro
Try the regular map to start with, and see if you are fine. If you overboost, switch to the LWG. If you dont hit targets, go for the HWG.
Old 12-30-2005 | 11:09 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
I personally like the ca. map
Old 12-30-2005 | 11:33 PM
Krinkov's Avatar
cant tune out a too-smal WG opening, soory
Old 12-31-2005 | 01:15 AM
SubyN00by's Avatar
turbo port time! call gruppe-s!
A170123W
07-06-2007 07:30 AM
carletto
07-23-2005 03:20 PM
willow
03-13-2004 08:41 AM
Speed Element
Vendor Group Buys/Specials
11-10-2003 09:58 AM
Quick Reply: Cobb AP .. which map fixes dp wastegate problem for STi?
