Blitz SBC Spec-S Boost Controller
Car Info: G35 Coupe (FOR SALE)
Blitz contact info
Blitz North America, Inc.
4879 East La Palma Avenue Suite 201-202
Anaheim CA 92807, U.S.A
(714) 777-9766 Phone
(714) 777-9763 Fax
Business Hours
Monday - Friday
9:00a.m. - 6:00p.m. PST
Email Us: Info@blitz-na.com
(714) 777-9763 Fax
Business Hours
Monday - Friday
Originally posted by palaban
If that doesn't work, PM me and I'll walk you through it. I have the Spec R.
Quickie How-To
To set the Gain (boost acceleration/momentum): Press and hold the Mode button down until you see 12345 flashing in the upper lefthand corner. Turn the volume to set boost. Keep this setting below 15.
To set the Boost ratio: turn the Mode button to channel 1. Press and hold the Mode button until the 1 blinks. Turn the Volume **** to set the ratio. Keeping this setting between 40 and 55 should keep you between 14-16 psi. After you've set the ratio, press the mode button so the 1 stops blinking. Turn the Mode **** to 2 and repeat.
Let me know if you need additional help.
I strongly suggest using a boost gauge to monitor.
Re: Quickie How-To
808_REX
04-08-2006 04:41 AM
