AP2 problem
Car Info: 2006 STI CGM
AP2 problem
So I just got an AP2 and tune at GST 2 days ago. Last night I'm showing my girlfriend what I bought. I leave my car and go to the garage, come back and my girlfriend has a nervous grin on her face.
She said she went to "sync with pc" and pressed ok. Now my AP says something along the lines of "attempting to connect" and "DO NOT DISCONNECT". I turned the car on and off, drove it for about a mile, and it still says it. I went to bed and when I woke up in the morning it still says it.
What do I do? If I disconnect will my custom map get lost?
Car Info: Broken Subarus
Your custom map should be saved in your AP. It is attempting to connect with a pc, until it finds a pc it will continue to say that. There shouldn't be a problem with disconnecting it with the key in the off position. Reconnect it after that and reload you map for peace of mind. If you're flashing you most certianly would not want to disconnect. Keep your GF away from you car/AP.
Speed Element
Engine and Drivetrain
11-06-2007 11:09 AM
