AccessPort - Valet mode
I did a search on here and nazioc but did not come accross what I was looking for. Might have overlooked it, so if someone has a link
Ive got APv2. Im taking my car in Monday to the body shop and it will be there for 3-4 days. I want to put the car in valet mode when I drop it off.
Does anyone know how to do so, or have a link?
Edit: Thanks ICB
http://www.accessecu.com/accessport/...03WRXMaps.html
Edit: Thanks ICB
heres the info on the map
http://www.accessecu.com/accessport/...ode%20v130.pdf
First thing that comes to someones mind when a car isn't running right is to clear the ecu and guess what. They probably will and then they will have a very fast car to play with.
My suggestion is to load the valet base map when you get there! The base map can't be removed by unhooking the battery.
1. plug in AP
2. connect two green plugs that are under steering wheel, may have to look a little but they are there
3. flash ECU with valey mode
4. disconnect green plugs
5. unplug AP
6. turn keys over to body shop
7. wait time to have them fix car
8. pick up car
9. plug in AP
10. connect green plug
11. reflash with other map
12. unplug green tabs
13. drive home in nice clean fixed car
make sure car is on during the reflash also. if you have any other questions please refer to the instructions that came with the AP.
5. unplug AP
8. pick up car
9. plug in AP
1. plug in AP
2a. Plug in blue connector (2002) or white (2003-up)
4a. disconnect blue/white connector
5. unplug AP
8. pick up car
9. plug in AP
5. unplug AP
8. pick up car
9. plug in AP
But yea thats exactly what I did yesterday
debelle wrx
07-18-2007 03:44 PM
1sicwrx
06-11-2006 10:07 PM
