Why you should Buy SARD Fuel Pressure Regulator??
Car Info: 03 Evo, 88 RX-7 T2
We did some research on different kinds Brands fpr can hold and this is what we found out!
1 Bar = 14.34 PSI
AEM:
1.4 kg/cm2 (bar) + no info
138 KPa + no info
OBX:
1.7 - 4.0 kg/cm2 (bar)
172 - 400 kPa
Aeromotive:
2.0 - 5.0 kg/cm2 (bar)
200 - 500 kPa
HKS:
200 - 500 kPa
Nismo/ Tomei:
2.0 - 6.0 kg/cm2 (bar)
200 - 600 kPa
SARD:
2.0 - 8.0 kg/cm2 (bar)
200 - 800 kPa
SARD FRP (Normal) - Regulator size is 50mm X 96mm and is ideal for most vehicles, up to ~450ps.
$105.00 an 06 fitting
$110.00 an 08 fitting
in 4 different color
SARD FRP (Type RJ) - Large Sized regulator 66mm X 92mm. For high power applications over 500ps
$210.00
Adaptor: 25.00 Dollars
Fuel Pressure Gague: 87.00 Shipped
1 Bar = 14.34 PSI
AEM:
138 KPa + no info
OBX:
172 - 400 kPa
Aeromotive:
200 - 500 kPa
HKS:
200 - 500 kPa
Nismo/ Tomei:
200 - 600 kPa
SARD:
200 - 800 kPa
$210.00
any pics available to happyturbo@gmail.com plz?
Originally Posted by orwrx
Do you have any brand of SS fuel line kit to go with that? Or do they normally come with the aftermarket fuel rail kit like Perrin?
Originally Posted by qax
is this made by sard too?
i'm confused....
so does this allow for better fuel flow for modified applications?
i'm running a turbo-back, stage 2 unichip, and 16psi....stock injectors.
what will this do for me? what about if i had say 740cc flow injectors?
Originally Posted by el_bobbo
i'm confused....
subieon17s
01-01-2007 10:49 PM
pbnj9786
08-03-2004 04:43 PM
