We now carry Perrin!!! Helix back in stock!!! Oil Coolers, Cams, Exhaust...
Hey all,
It's a big week for us. We are proud to announce that we now carry Perrin and will be getting our first stocking order in in the coming week. We also just got a large Helix shipment.
Individual Components:
Helix Catted Downpipes - $399 shipped
-Will pass emissions
-Bellmouth design, full 3"
-Dynoproven to make power
Helix Flex Uppipe - $175 shipped
-High quality Flex joint allows for perfect fitment w/o risk of cracking
-Removes cat on 02-05 WRX (best bang for the buck mod on WRX)
-Bigger diameter than stock uppipe
Helix Catback - $499 shipped
-Full 3" piping (does not taper)
-Full stainless steel, comes with all gaskets and hardware
Gruppe-S V2 4-1 Manifold with Jet Hot 2000 - $575 shipped !
The Gruppe-S manifold is a 4 to 1 manifold designed to provide extensive midrange and top-end power gains. Our manifold features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. Strong gains in both HP and torque can be expected with the addition of the manifold, especially with high horsepower applications. The Jet Hot 2000 outside coating eliminates heat loss thus virtually eliminating low end power loss (compared to stock headers). These are the best coated headers we have ever seen; the coating is evenly applied with no bubbles and is absent from all bungs and threading. Includes all necessary gaskets.
Gruppe-S V2 Manifold - 02+ WRX / 04+ STI - $399 Shipped!
**Dyno graphs shows testing with 04 WRX catted downpipe, uppipe, exhaust, versus addition of manifold only.
Helix RNA Series Valvetrain and Cams- 2001+ Subaru Impreza EJ20 (non-AVCS) $999 shipped
The Helix RNA camshafts are designed specifically for high power Subaru applications without sacrificing drive-ability and streetability. The RNA cams work well on the 2.0 platform, with a minor reduction in low end torque while providing truly impressive mid and top end power gains of over 20+ whp, and truly come alive on larger 2.2 or 2.5 liter applications by providing the extra intake and exhaust that the larger displacing engines need.*
*Helix Valvetrain is recommended for Helix Cams.
Helix RNA Series Cams- 2001+ Subaru Impreza EJ20 (non-AVCS) $519 shipped
While it is highly recommended that these cams are used in conjunction with the Helix Valvetrain, they can also be used with your stock valve train (which allows for 10mm of lift).
-SPECS: 264 Duration, 9.6mm Lift,Titanium Retainers, Dual valve spring, with spring seats
-APPLICATION: EJ205 / EJ207 Non-AVCS only
-RECOMMENDED MAXIMUM REDLINE: 8500RPM (w/ Helix valvetrain and supporting bottom end only)
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Combos:
Helix Catted Turbo Back Exhaust - $849 shipped
Helix Catted Turbo Back Exhaust + Gruppe-S Header - $1199 shipped ($1375 shipped for Jet Hot Coated)
Helix Catted Turbo Back Exhasut and Uppipe - $999 shipped
Helix Catted Turbo Back Exhasut and Uppipe + Gruppe-S Header - $1349 shipped ($1525 shipped for Jet Hot Coated)
Helix Uppipe / Catted Downpipe - $525 shipped
Helix Uppipe / Catted Downpipe + Gruppe-S Header - $875 shipped
Helix Power 660cc Injectors for WRX + Walbro 255L FP and setup kit - $539 Shipped!
$459 Shipped for just the Injectors!
- Ideal for VF series and PE size turbos on WRXs
- 340WHP Capable
Helix Power 800cc Injectors for WRX + Walbro 255L FP and setup kit - $559 Shipped!
$479 Shipped for just the Injectors!
- Ideal for large turbos on WRX: Green, 20G, GT30R, etc.
- 510 WHP Capable
Helix Power 860cc Injectors for STi + Walbro 255L FP and setup kit - $579 Shipped!
$499 Shipped for just the Injectors!
- Ideal for 20G, Green, Red, GT30R, GT35R, etc.
- 550WHP Capable
Helix Catch Can - $75 Shipped!!!
The Helix Catch Can is designed to trap oil moisture and blow-by caused by normal engine operation, especially in turbo charged vehicles. On your factory vehicle, because of emissions regulations, the waste oil and sludge is generally re-routed back into the intake stream. This debris will tend to accumulate inside the intake tract, intercooler, turbocharger, as well as be ingested into the engine during normal combusion process. Needless to say, this sludge and blow-by will hurt the performance of your vehicle. The Helix Catch Can eliminates this problem by trapping such debris and insuring optimal horsepower and longevity of you vehicle.
An affordable Oil Cooler done the right way!
While track-side tuning Brian Locke’s WRX US Touring Car, the WRX’s ability to sufficiently cool its oil when operating in extreme conditions became glaringly apparent. Even in cool weather with moderate cycling, the factory system seems stressed, resulting in dangerously high oil temperatures (this is probably why the Spec C’s come with an oil cooler from the factory). After testing various solutions, we finally selected a setup that is more than capable of dealing with the stress of road racing.
With the Gruppe-S Oil Cooler, the racing oil temperature was reduced a consistent 40 degrees F, even in 110 degree + temperatures of Arizona, as proven with our data logs. In short, this oil-cooler works and it has been track tested on a race winning vehicle.
Key Features:
*High quality European core (240mm x 120mm x 45mm), not some Taiwanese knock off core.
*Thermostat operated Oil Cooler to avoid cooling cold oil upon startup.
*Aerospace fittings / stainless steel lines, professionally assembled and tested to 1000psi.
*Light weight mounting brackets.
In the words of Brian Lock, “this oil cooler rocks. After installing this setup we never had a problem with oil temperature again. Even at PIR where it was 115 and it was so hot inside the car I thought my legs were on fire, it was golden. Brian Lock thinks that this oil cooler is the *****, Brian Lock thinks you should buy it.”
$499 Shipped!
Gruppe-S Intercooler Hose Kit for 02+ WRX $99 shipped !
The Gruppe-S intercooler hose kit replaces the corrugated rubber stock y-pipe, smoothing flow and increasing the airflow diameter, making for a nice increase in power and better boost response. Includes a cast-aluminum Y-pipe, premium quality 4-ply silicon hoses, clamps. This kit will work for STi TMICs being installed on WRXs.
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
- 340WHP Capable
- 510 WHP Capable
- 550WHP Capable
Key Features:
$499 Shipped!
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
Perrin:
WRX Fuel Rail Kit - $359 shipped
-Solves all fuel distribution problems by dividing fuel evenly between the fuel pressure regulator and both banks of cylinders in the boxer engine.
-Stainless steel teflon coated lines.
STi Fuel Rail Kit - $359 shipped
Perrin Front Mount IC - $1099 shipped
-Rated for 500-800 HP
-Low pressure drop across core, efficient core.
-Comes w/ new bumper beam
Perrin Signiture Series FMIC - $1175 shipped
-Comes w/ wrinkle red piping
Perrin Rotated Mount GT30R Kit - $2499 shipped
-Includes uppipe, downpipe, GT30R turbo (.63 or .82 A/R), Tial 44mm W/G, intake, big MAF, inlet hose
-550+ HP
Perrin Rotated Mount GT35R Kit - $2699 shipped
-650+ HP
Perrin Big MAF - $209 shipped
-Allows more air to travel through the MAF without maxing it
-Highly recommeded for 20G / Green and larger sized turbos
-Requires tuning
Perrin Turbo Inlet Hose - $209 shipped
-Smooths airflow into turbo
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
-550+ HP
-650+ HP
-Requires tuning
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
GS600 - 2.5 Short Block (Stage 2) in stock and ready to ship!!! - $3299 + Shipping
-Gruppe-S / Wiseco Forged Pistons
-Gruppe-S Coated High Performance Rod & Crankshaft bearings
-STi Race Crankshaft (nitrated, magnafluxed, lightened)
-ARP Headstuds (on long-block option)
-Cometic Head Gaskets (on long-block option)
-Professionally balanced rotating assembly (recommended 7500+ RPM redline)
-Rehoned cylinder walls
-Capable of up to 600HP Operation
-Final Displacement 2.48L
-Compression ~8.5 : 1
Turbo Packages:
IHI VF34 + STI 565CC Injectors OR Helix Power 660cc Injectors + Walbro Fuel Pump-375HP Capable on a WRX (with proper tuning)
-Includes Genuine IHI VF34
-Genuine STI 565cc Pink Injectors
-Walbro 255l/h Fuel Pump
$1299 shipped!!!
IHI VF34 + STI 565CC Injectors OR Helix Power 660cc Injectors + Walbro Fuel Pump+Ecutek Reflash
-Send us your ECU and we'll reflash it and we'll overnight it back to you
$1999 shipped!!!
IHI VF34 + STI 565CC Injectors OR Helix Power 660cc Injectors + Walbro Fuel Pump + Installation + Ecutek Reflash + Custom Dynotune
-Please call to schedule an appointment
$2349 shipped!!!
Random Items:
SARD R2D2 BOV's - $239 Shipped!!
-Adjustable BOV Spring Load - Ensure that the BOV doesn't leak at idle
-Nomex Seal - Ensures tight piston seal to warrant against leaking
-Twin Drive - Maximum venting and Great Sound
-Blue SARD Racing Silicon Hoses included
-SARD Parts Bag containing Hose Clamps, Zip ties and T-Piece
-Designed for street cars to high boost track cars!
Cusco Downpipe - 02+ WRX / 04+ STi - JDM Spec - $425 Shipped!!
-JDM Spec - shorter length makes it compatible with JDM Spec exhausts
-Divorced waste gate design
Apex'i Induction Box - 02+ WRX / 04+ STi - JDM Spec - $150 Shipped!!
By fully enclosing the filter element and directing the intake air away from the heat soaked engine components, the APEXI WRX induction box helps prevent the ingestion of hot, preheated air from within the engine compartment. This reduction of intake air temperature promotes more efficient combustion, which in turn creates better performance and increased reliability. The box does not include a new filter.
Greddy Air Inx Intake Kit - 02+ WRX / 04+ STi - JDM Spec - $120 Shipped!!
The Greddy Air Inx intake features a dual element foam filter which is more adept at filtering than your stock filter. It also allows for increased air flow which, when coupled with increased fuel, results in increased power.
Accessories:
Cusco Aluminum Radiator Shroud (blue) - 02+ WRX / 04+ STI
Approximately 20% of incoming air current is diverted away from the radiator by the radiator support. The radiator shroud reduces this loss, by redirecting airflow over the radiator. The result is an increased cooling efficiency of the radiator.
$99 Shipped!!!
Gruppe-S Heat Shield- 02-05 WRX
This heatshield will lower your underhood operating temperatures by directing heat from the turbo and downpipe away fromt your TMIC and the rest of your engine. This will in turn lead to more power from cooler intake temperature and better engine operating conditions.
$49 Shipped!!!
RC Engineering 650cc Injectors (Top Feed) - 02-05 WRX - $300 shipped
These are high impedence saturated top feed injectors. They flow 650cc and have been flow tested by RC Engineering. They will drop into any EJ20 Subaru Impreza WRX motor. These will not fit an STi. You will need to modify your harness to use them. These injectors will support and VF series turbo (30, 34, 39, etc.) or 16g or 18g.
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
Turbo Packages:
$1299 shipped!!!
$1999 shipped!!!
$2349 shipped!!!
Random Items:
Accessories:
$99 Shipped!!!
$49 Shipped!!!
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
Originally Posted by sigma pi
any pics of the oil cooler installed
where do you mount it?
question, will gruppe-s ever make a heat shield for the sti?? or do they already?
Thanks,
Geoff
gruppe-s
Engine and Drivetrain
03-14-2006 03:43 PM
gruppe-s
03-14-2006 03:41 PM
gruppe-s
03-07-2006 02:59 PM
gruppe-s
03-07-2006 02:46 PM
gruppe-s
02-24-2006 07:22 PM
