STI V6 RA GEARSETS - $1999 INSTALLED!!! (2 at this price)
Old 11-03-2006 | 05:08 PM
gruppe-s's Avatar
Hey guys,
We are offering:
GENUINE V6 STI RA GEARSETS - INSTALLED!!
Genuine Subaru RA Gearsets - Cryoed
The STI RA V6 gears are a found in the rally-bred Version 6 Impreza STI RA and is designed to be a much beefier swap for your WRX 5-speed transmission. The thicker gear teeth as well as the inherently stronger gears and shaft are a perfect solution for customers looking for gear-sets that will hold more power. For further strengthening all gear-sets are CRYOGENICALLY TREATED.
All gearset kits include STI RA Gears 1-5, main shaft, properly matched speed-o gear, and shifter fork. Please see our bearing and synchro sections for a complete rebuild kit. Rebuild time is generally 5-6 hours of bench time (not including removal & installation) and if your transmission is damaged will usually require new bearings and synchros.
Gear Ratios:
First Gear 3.083
Second Gear 2.062
Third Gear 1.545
Fourth Gear 1.151
Fifth Gear 0.825
$1999 INSTALLED!! (plus tax)
WE HIGHLY RECOMMEND NEW BEARINGS & SYNCHROS - ADD $599
Turn around is about 5 days on the transmission rebuild. Please give us a call to schedule an installation. Our techs are ASE certified master techs.
Thanks!
Gary
Gruppe-S
510-783-5300
510-783-4300 fax
Old 11-05-2006 | 12:17 AM
DanyoCantDrift's Avatar
The weal amewican hewo!
these arent the "se" gears are they ,that retain the stock wrx 5th gear?
Old 11-06-2006 | 12:28 AM
gruppe-s's Avatar
Sorry, we're all sold out on the SE gears. If you want to put down a deposit, I can gaurantee you a set on our next batch in early dec. We have 2 RA gears left because customers backed out. Thanks!
Gary
gary@gruppe-s.com
Old 11-08-2006 | 05:11 PM
gruppe-s's Avatar
Bump, one set left!
Thanks,
Gary
Old 11-08-2006 | 11:26 PM
Wildblitz1337's Avatar
Car Info: 89 honda civic (sedan)
how much for just parts...gears and synchros
Old 11-16-2006 | 01:54 PM
gruppe-s's Avatar
Hey guys,
Sorry sold out, if you want to set something up for December (our next shipment) please give us a call. Thanks!!
Gary
Gruppe-S
speedykanaan
07-20-2012 01:23 PM
gruppe-s
03-09-2005 01:34 PM
gruppe-s
Vendor Group Buys/Specials
12-09-2004 12:26 PM
gruppe-s
10-26-2004 07:04 PM
gruppe-s
12-11-2003 01:21 PM
