STi V6 RA Gearset
STi V6 RA Gearset
Have one left guys - includes everything needed to swap into a 2002 and up WRX.
These gearsets are brand new STi Spec parts from the famed Version 6 model from Japan. We offer these gearsets in 2 forms - Sti and STi RA. The RA was the version homologized for Group N use, hence its shorter gears. Acceleration with the RA gearset is simply a monster; the standard STi gear ratios are much closer to those of a factory US Spec WRX as you can see.
Stock WRX Ratio: 3.454 (1st) 1.947 (2nd) 1.366 (3rd) 0.972 (4th) 0.738 (5th)
STi RA ratios: 3.083 (1st), 2.062 (2nd), 1.545 (3rd), 1.151 (4th), 0.825 (5th)
STi (Non-RA) ratios: 3.166 (1st), 1.882 (2nd), 1.296 (3rd), 0.972 (4th), 0.738 (5th)
Gearsets include main shaft, 1st-5th gears, and all necessary parts for proper installation including locknuts, gaskets, and seals. These are setup for painfree installation into a 2002-2004 WRX or 2.5 RS (some extra items required - contact us for details). These gearsets are designed to be installed into gearboxes in generally good condition. If catastrophic failure has occured, you may also need to purchase additional items - contact us for details as we can supply you with everything needed, right down to new synchro's.
Priced at $1450 shipped
Orders can be placed on our site via Paypal or credit card by clicking here:
http://www.z1auto.com/prodmore.asp?m...ne&prodid=1154
2.2gotboost
05-06-2004 06:45 PM
subarusucks
04-29-2004 04:34 PM
imdiaw
04-24-2004 01:18 PM
