RA Gearsets, Bushings, Mounts, guaranteed *best* pricing on ACT, Exedy!!!
Hey all,
Our RA gears are out being cryoed but almost all of them are already presold. We have a few sets left that are currently unspoken for. If you've been waiting for these, now is the time to get them!!!
Version 6 STI RA (Special Edition) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- Stronger than stock WRX gears
- 1mm thicker gears
- Cryotreated for added durability
- Includes new bearings and synchros
- Replace gears 1-4 (shorter ratios)
- Retains stock 4th and 5th gear ratios
- Better accelleration, same cruising fuel mileage
Version 6 STI RA (Normal) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- 1mm thicker gears
- Replace all gears (shorter ratios)
- Ideal for track
Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $250 Shipped
These mounts are stiffer than the STi Group N mounts and are designed to reduce excessive flex in the stock mounts.
STi Group N Tranny Mounts - 02+ WRX / 04+ STi - $69 Shipped
The STI "Group-N" Transmission Mount is designed to reduce excessive motion of your transmission during shifting and launching. This is done by increasing material stiffness over your stock transmission mount. By decreasing this type of motion, more energy is focused to the drivetrain and chassis rather than spent twisting your transmission. These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi.
STi Group N Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $159 Shipped
The STI "Group-N" Engine and Tranny Mounts are designed to reduce excessive motion of your motor and transmission during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine and tranny mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine and tranny. These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi.
2) JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$319 Shipped for 5/6th Gear Conversion
$769 for rebuild w/ 5/6th Gear Conversion
Cusco Shifter Bushings - 02+ WRX
$37 Shipped
Also, we now carry Kartboy products! Please PM for pricing and combos.
http://www.gruppe-s.com/Subaru/subtrn.htm
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
- 1mm thicker gears
- 1mm thicker gears
- Ideal for track
Ratios:
$37 Shipped
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
OK, we know everyone claims to have the best pricing on ACT and Exedy but take a good look around and then compare to our prices. We're fairly confident that we really do have the *BEST* pricing on ACT and Exedy. If we don't, let us know and we'll beat our competitors pricing.
1) Exedy Organic Clutch Kit and ACT Steetlite Flywheel (Stage 1)- 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3)- 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Twin Plate Clutch/Flywheel Kit (Stage 4)- 02+ WRX
-Clamp Load: 2205 lbs/ft.
4) Exedy Organic Clutch Kit and Steetlite Flywheel (Stage 1) - 04+ STi
-Weight: clutch - 14.3lbs, flywheel - 15.4 lbs.
$925 Shipped!!!
$1350 Installed!!!
5) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3) - 04+ STi
6) Exedy Twin-Plate Clutch/Flywheel Kit (Stage 4) - 04+ STi
1) ACT HD Street Disc Kit and Steetlite Flywheel (Stage 1) - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel (Stage 1) - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
$750 Shipped!!!
$1175 Installed!!!
$925 Shipped!!!
$1350 Installed!!!
$649 Shipped!!!
$1100 Installed!!!
$699 Shipped!!!
$1119 Installed!!!
$855 Shipped!!!
$1275 Installed!!!
$879 Shipped!!!
$1299 Installed!!!
$699 Shipped!!!
$1119 Installed!!!
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
gruppe-s
07-21-2006 12:41 PM
gruppe-s
Engine and Drivetrain
07-19-2006 07:26 PM
gruppe-s
06-29-2006 02:52 PM
gruppe-s
06-26-2006 12:56 PM
gruppe-s
04-25-2006 11:38 AM
