Power Enterprise! Need A Turbo Buy It From One Of The Best!!!!
Car Info: 05 sti
We have some power enterprise turboes, here in our shop. With an amazing deals on them. If you want to know you have to PM me or call the shop at 1-415-839-0058 or 1-415-839-0068
Sample image shows PE1818F & PE1820Fw/ Rebuildable(separative) actuator and for the USDM
GDB (single scroll)
IMPREZA BOLT ON TURBO KIT
The most popular turbines for GC8, GDA, DGB &BF8/EJ20 engines. The best rated turbo for the price and performance in the tuning and racing fields.
※ 2 different stages of turbines are available. PE1818 (A/R18) is suitable for low to mid response and PE1820 ( A/R20) is suitable for mid to highrpm range response.
PE1818F MSRP: $2280
PE1820F MSRP: $2280
Your Price: PM FOR PRICE TOO CHEAP TOO LIST!
PE1818F or PE1820F
w/ Rebuildable
(separative)
Actuator $2380
Sseparative Actuator is an unique part developped by PWR to be able to replace differnt stffiness of actuator springs for higher boost applications.
Image shows above is PE1825F (twin scroll)
for JDM spec of GDB
IMPREZA GDB STi Stock replacement bolt-on F1 turbo "PE1825F"is the quickest response turbo in the world.
As opposed to the single-exhaust entry turbine housing on the previous GDB model, the newer GDB STi has the twin-entry, designed for smoother exhaust gas entry to the turbine housing without having exhaust interference from the left & right banks. Torque and response at low to mid range are drastically improved by utilizing thetwin entry and as allways the PWR turbo's feature the ball bearings. The compressor wheel of big 70mm easily supports monstrous quick spooling 400++ps of power all the way to the high RPM range. The bolt on installation needs no additional work
.Boost range 1.3 ~ 1.4 kg
A/R : 25 (400+ps application)
Compressor wheel diameter: 70mm
Turbine housing : twin-entry
Center section : ball bearings
PE1825F for Impreza
GDB STi MSRP$3200
PE1825F for Impreza
GDB STi
w/Rebuildable(separative)
Actuator $3300. Sseparative Actuator is an unique part developped by PWR to be able to replace differnt stffiness of actuator springs for higher boost applications.
++CA Residents please include sales tax
GDB (single scroll)
PE1818F MSRP: $2280
PE1820F MSRP: $2280
PE1818F or PE1820F
w/ Rebuildable
(separative)
Actuator $2380
for JDM spec of GDB
PE1825F for Impreza
GDB STi MSRP$3200
PE1825F for Impreza
GDB STi
Amandyke
03-16-2011 05:04 PM
ImportImage
27
11-22-2005 12:44 PM
Z1 Performance
Vendor Group Buys/Specials
08-27-2004 08:28 PM
SwtAzn_WRX_gurl
03-25-2004 10:01 PM
