Perrin Parts! Titek Downpipes! Greddy & Borla Exhausts! Cobb AP2! Turbo Kits & More!
SpeedElement is your Perrin Authorized Dealer!!
--All Perrin Hoses come in RED, BLACK, or BLUE. Choose color when ordering!--
New Perrin Turbo KITS!
When basic bolt ons won’t do or you have simply stalled out with the performance of the factory turbo then Perrin's Rotated Turbo Systems are the place to go! With kits that range in power totals from 350 WHP to more than 600WHP we have any boost junkies needs covered.
All Kits include: stainless steel up pipe and down pipe, Tial 44 wastegate, a new complete intake system, oil and water lines,and the Turbo.
GT3071R kit $2999 shipped!
GT3076R kit $3099 Shipped!
GT3582R kit $3250 shipped!
Perrin FMIC Kit: 02-07 WRX/STI
The PERRIN Performance Front Mount Intercooler is huge. Delivering higher cooling capacity and a significant reduction in intake temperatures. Cast aluminum end tanks and a bar-and-plate design offer smooth airflow and even pressure while retaining the stock bypass valve-mounting flange. Polished: $1,153 shipped! Signature (red) or New Stealth (black): $1242 Shipped
Perrin Blow-thru Boost Tube: 02-07 WRX/STI
PERRIN Front Mount Intercooler users can now get a more accurate charge temperature reading and run a VTA BOV with no problems! Instead of measuring the Mass Air Flow (MAF) and air temperature before the turbocharger, the PERRIN PerformanceTM Blow-Thru boost tube moves the mass airflow sensor to the boost tube before the throttle body. The placement of this does many good things like allowing your ECU to read the actual charge temp the engine sees, which eliminates any need for a Cold air intake.
MSRP:$229.99, YOUR PRICE $207 FREE SHIPPING! Polished, Signature (red) or New Stealth (black)
PERRIN Performance™ TMIC
Perrin TMIC Fits 04-07 STI. These bar and plate cores offer more surface area per square inch than cheap tube and fin choices from our less worthy competitors and the overall size is more than 200% of the OEM unit!
MSRP:$799.99, YOUR PRICE $720 FREE SHIPPING!
**For 02+ WRX add $140 for Y-Pipe kit.**
Perrin Intakes!
PERRIN Performance™ Big MAF
The PERRIN Performance™ Big MAF intake system is designed to prevent the Mass Air Flow output value from being pegged on heavily modified WRX engines. When using the factory MAF sensor and adding large amounts of boost the stock MAF sensor will max out and not allow additional compensation for air flow.
MSRP:$219.99, YOUR PRICE $195 FREE SHIPPING!
Perrin Short Ram Intake
Manufacturing one of the only properly positioned and sized MAF sensor adaptors for the WRX, Perrin intakes are able to achieve higher horsepower numbers then their competitors.
MSRP: $189.99, YOUR PRICE $170 FREE SHIPPING!
Perrin Cold Air Intake
One of the only properly positioned and sized MAF sensor adaptors for the WRX, Perrin intakes are able to achieve higher horsepower numbers then our competitors.
MSRP: $299.99, YOUR PRICE $270 FREE SHIPPING!
Perrin Panel Filter
Add horsepower and torque without replacing the entire air box assembly.
The PERRIN Performance dual stage drop in panel filter provides maximum power gains while removing harmful particulates from the air charge.
This is a direct replacement for the factory panel air filter. Comes pre oiled and ready for installation.
Fits: WRX, STi, Forester XT and Baja!
$39 FREE SHIPPING!
Perrin AFTA-MAF Tube
Simple to install and easy to appreciate, the AFTA-MAF™ is an eloquent compliment to every engine bay. Replaces the factory corrugated rubber hose between the inlet tube and air box.
MSRP, $79.99, NOW $70 FREE SHIPPING!!!!
Perrin Turbo Inlet Hose Kit
Fits: IHI VF series turbo, FP Green, and etc..
MSRP $249.99, YOUR PRICE $225 Free Shipping!!
Perrin 3" Turbo Inlet Hose Kit
For Large Turbo setup such as FP Red.
MSRP $259.99, YOUR PRICE$235 Free Shipping!!
PERRIN Performance™ Subaru STI Fuel Rail Kit
This kit solves all fuel distribution problems. Perrins fuel rails direct fuel to both banks of cylinders and to the fuel pressure regulator. Even fuel distribution is achieved through the PERRIN™ design guaranteed! PERRIN Performance™ fuel rails are specifically designed for the 04-06 Subaru STI side feed injectors to retain correct fuel injector alignment. THE PERRIN FUEL RAIL KIT INCLUDES: BILLET ALUMINUM RAILS FUEL PRESSURE REGULATOR MOUNT STAINLESS LINES AND FITTINGS.
MSRP, $379.99, NOW $350 FREE SHIPPING!!!!
Perrin Crank Pulley
Weighing in at 1.2lbs, this pulley is more then 4 lbs lighter then the stock crank pulley. The Perrin pulley is not under driven and will not affect the life of your engine!
Fits: WRX, STi, Forester XT and Legacy GT
MSRP $134.99, YOUR PRICE $120 FREE SHIPPING!
Perrin Intercooler Hose
Increase airflow over stock intercooler hoses with PERRINs redesigned air passages insuring equal boost to all areas of any top mount intercooler.
MSRP $159.99, YOUR PRICE $145 FREE SHIPPING!
Perrin Radiator Hose
Made of high gloss vividly colored silicone, Perrin radiator hoses are an excellent compliment to your existing Perrin intake system or inlet hose.
Fits: WRX and STi
MSRP $149.99, YOUR PRICE $135 FREE SHIPPING!
Perrin Equal Length Header
Constructed from 321 stainless steel and 1/2 flanges the header is designed to withstand the most punishing levels of heat your engine can dish out. Fits all 2002-2007 models. (2.0 WRX models will require a STi type oilpan for clearance.)
MSRP $799.99, YOUR PRICE $720 FREE SHIPPING!
Perrin Front and Rear Section Down Pipes Availible too
YOUR PRICE $PM For Pricing FREE SHIPPING!
---Titek Catted Down Pipe Super Sale!! ---
Perfect fitments on these! Not like some new redesigned pipes on the market today and full bell mouth design!
Titek Catted Down Pipes!! - $399 Shipped!!
- Titek Catted Down Pipe Combo Deals-
Get Titek DPs mated to an Apexi N1 catback!!
Add Apexi N1 catback to your Catted dp for $924 Shipped!
Apexi N1 alone - $540 Shipped
- Order here: http://www.speedelement.com/index.ph...mart&Itemid=38
*titek uppipe, titek catless dp and invidia n1 on wrx 2.0L makes 214 whp and 200 tq* (with ecutek tune)
Borla Hush - PM for BEST Pricing!
- Or order here: http://www.speedelement.com/index.ph...mart&Itemid=38
Titek Catted DP + Borla Hush - $1010 Shipped PM for BEST Pricing!
Add $50 for 3" adapter on Borla exhausts.
--Invidia Cattless Down Pipe (Divorced Wastgate)--
$355 shipped One of the highest horsepower dps on the market!
--Tanabe Catless Down Pipe!--
$345 shipped
--Cobb AP V2 Combos--
Titek CATLESS down pipe, Apexi NOIR and Cobb AP2 all for $1375 shipped!!!
Titek CATTED down pipe, Apexi NOIR and Cobb AP2 all for $1575 shipped!!!
GReddy Racing Ti-C 3" Cat-back Exhausts!!! $549 shipped!!!
Hear it here: http://www.youtube.com/watch?v=K9X9eLZWMYk
Add the Titek Catted DP to the Greddy TI-C for $945 shipped!!!
More Great Parts!!
Walbro Fuel Pumps!
Walbro 255 lph Fuel Pump - $90 shipped
Add Walbro WRX Setup Kit to the pump for - $15 *not sold separately*
Greddy Timing Belts!!
Engineered to increase heat-resistance, flexibility and durability, GReddy Extreme Timing Belts reduce the chances of cracking from heat, inconsistent timing from stretching and skipping or snapping. Improvements in materials and construction lead to a more reliable belt that will be more consistent and last longer. For EJ20 motors.
$168 Shipped!! Order here: http://www.speedelement.com/index.ph...mart&Itemid=38
--Sun Automobile!!--
Sun Automobile!!
Hyper Ground System - Cyber Speed
Giving your car a more efficient ground will help to pull out its full performance potential! The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals.
$144 Shipped!
Hyper Force System
We have seen a 10hp gain from this system on our Dyno Dynamics Dyno!!
$350 Shipped! Including WRX harness!!
Hyper Voltage System - Cyber Speed
Designed to stabilize voltage in your vehicle for maximum battery efficiency and allowing its full potential to be released.
$244 Shipped!
Check out ALL of the Sun Automobile products we carry as well as more info and pix in our online store!! http://www.speedelement.com/index.ph...mart&Itemid=38
And don't forget we are a Cosworth authorized dealer!!
Need pistons, head studs, rods, cylinder heads, or even complete race motors? Order directly from our online store! http://www.speedelement.com/index.ph...0&limitstart=0
As always you can check out our website for more items as well!! www.speedelement.com
To order click on the direct link for item,
paypal: sales@speedelement.com to order or give us a call at 510.226.8822
FREE SHIPPING only applies to lower 48 states.
*CA Residents please add local sales tax* Paypal add 3% fees
Rob
Speed Element/MPJ Performance
www.speedelement.com / www.mpjperformance.com
44875 Industrial Drive Unit B
Fremont, CA 94538
Perrin Intakes!
Perrin Panel Filter
$39 FREE SHIPPING!
Perrin Crank Pulley
Fits: WRX and STi
$345 shipped
More Great Parts!!
Walbro Fuel Pumps!
Sun Automobile!!
$144 Shipped!
Hyper Force System
$244 Shipped!
Rob
Fremont, CA 94538
Sun Automobile!!
$144 Shipped!
Hyper Force System
We have seen constant 7hp gains from this system on our Dyno Dynamics Dyno!!
$244 Shipped!
More details and images on our website!! http://www.speedelement.com/index.ph...mart&Itemid=38
$144 Shipped!
Hyper Force System
$244 Shipped!
Heres the dyno charts of the Hyper Force as promised on an 02 WRX wagon. The car has Greddy TIC catback, Stock Downpipe, STI TMIC, and SPT intake with Apexi Filter. Before and after plots. ONLY the Hyper Force was added in between runs!!! No additional tuning.
Yes, thats a 10.5 WHP gain!
gotshotgun
02-03-2012 07:28 PM
Speed Element
Engine and Drivetrain
05-13-2010 11:10 AM
Speed Element
03-26-2008 04:24 PM
Speed Element
10-25-2006 11:33 AM
DCH Motorsports
11-28-2005 08:25 AM
