New Products! 6spd Synchro / Bearing Kit and JDM 5th and 6th Close Ratio Convesion!
Hey all,
We have a couple of new products for you.
1) Genuine Subaru Synchro & Bearing Kit for 6 Speed Manual Transmission (13 pcs) - 04+ STi
We have packaged together the most commonly damaged synchros and bearings for the Subaru STI 6-speed transmission. In all likelihood if a transmission rebuild is necessary these synchros and bearings also need to be replaced. These are in stock and ready to ship. You can also send us your 6spd. to be rebuilt with these.
2) JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$419 Shipped for Synchro and Bearing Kit
$319 Shipped for 5/6th Gear Conversion
$719 Shipped for Synchro and Bearing kit, and 5/6th Spd. Conversion
$869 for rebuild w/ new Bearing and Synchro Kit
$769 for rebuild w/ 5/6th Gear Conversion
$1149 for rebuild w/ new Bearing and Synchro Kit, and 5/6th Spd. Conversion
Thanks,
Preston
510-783-5300
preston@gruppe-s.com
Ratios:
Thanks,
Preston
510-783-5300
gruppe-s
10-14-2005 06:34 PM
gruppe-s
10-14-2005 06:31 PM
gruppe-s
07-26-2005 01:08 PM
