JDM V8 SUBARU IMPREZA WRX EJ20 ENGINE (AVCS) - 6 engines available immediately!!!
Hiya,
We have 6 engines available:
$1649 + Shipping
THE JDM V8 Subaru Impreza WRX EJ20 Turbo Engine (AVCS) is superior to its USDM cousin in several aspects. As usual, the USDM WRX receives an inferior engine based on the older V6 GC8 motor.
The JDM WRX EJ20 on the other hand received an engine with all the bells and whistles that one would expect of a high performance engine. While the 2.0 displacement remains the same, the JDM WRX features a bump in compression (8.0 -> 9.0), better pistons developed using new hyper-cast technology (such as in the USDM STI), more aggressive cam profiles, better head casting, and of course the all mighty AVCS.
For those who are not familiar with AVCS, AVCS is a control device on the intake cams of the engine. Using an oil based pressure system, the cam timing is either retarded or advanced to increase or decrease overlap. This type of overlap essentially helps to create a “perfect” camshaft, allowing maximum power output throughout the power band while also assisting in emissions cleanliness.
The bottom line is the JDM WRX engine (rated at 246HP compared to 227HP) is far superior to the USDM WRX engine, and is what the USDM engine should have been. The improvements significantly reduce the notorious turbo-lag associated with the USDM WRX, allow the JDM engine to respond better to aftermarket modification, and produce a higher power output.
Swapping a JDM WRX engine into a USDM WRX is a fairly straightforward process – the engine drops right in. The stock ECU is fully compatible with this engine, although you will not have the option of controlling AVCS. This is not a problem if you wish to go this route, as the AVCS will default into high lift mode and you will not lose any of the top end power (although you will not enjoy the benefits of the AVCS midrange). If you want to run AVCS this is also not a problem, simply pickup a JDM ECU (we offer these for sale), run a couple of additional wires for the AVCS control, and AVCS is hooked up. An ECU reflash is required for anyone not running less than 96 octane.
We offer installation services, ECU reflash, professional dyno-tuning, and can also convert your JDM WRX engine into a 350+ HP engine with very little cost.
Please contact us with any questions and appointments.
Thanks,
Gary
Gruppe-S
$1649 + Shipping
Thanks,
Gary
Gruppe-S
Car Info: 2004 WRX Wagon JAVA BLACK PEARL
where is hayward in california? i have family all over california so do you do pickups? if not how much for shipping to fullerton california zip code 92832?
Originally Posted by PSI-PWR
SOLD!! how much for motor + ecu shipped to 96776?
Originally Posted by SQR
will the EJ20T drop right into a GC8 body?
Geoff
about how much total are we talking about to drop this motor and have it fully running in a GC8 1999 body?
would puting lower octane gas that we have here (91 or 93) affect the performance of the engine since Japan uses better gasoline?
Jdallas87 - Yes, it would. You would want to get it reflashed.
Preston
question
i live in SF
i have quite a few mods of my wrx
will u guys able to transfer all the mods to the new engine?
do u guys even install for customer and how much?
how many motors left & how much for the jdm ecu reflash?
EVOKILA1 - Yes, we can transfer your mods to the new motor and yes we do offer installation.
Preston
gruppe-s
09-19-2005 06:52 PM
gruppe-s
Engine and Drivetrain
09-19-2005 04:57 PM
gruppe-s
Vendor Group Buys/Specials
18
12-06-2004 02:13 PM
EndlessWaltz RS
Wanted
04-29-2004 02:45 PM
