JDM Container - Lots of Cusco!!!
Cusco!
Cusco V2 Lower Arm Bar - 02+ WRX / 04+ STi
-The purpose of the Cusco lower arm bar is to reduce alinement flexing and improve body rigidity. The lateral arm improves body and rigidity by connecting at the lower arm points. Thus preventing body flex and therefore dramatically improving steering, throttle response and traction. The Version II Bar mounts by multiple bolts and the lateral and foe aft rigidity is greatly increased over Version I.
$150 shipped OR OTD and picked up (includes tax)!!!
$215 installed and OTD!!!
Cusco 22mm Rear Sway Bar (3-way Adjustable) - 02+ WRX
-Often described as the single most aggressive suspension modification for your Impreza, the addition of stiffer swaybars properly distributes cornering forces by reducing lateral sway applying increased cornering force on the outside wheel and will ultimately increase vehicle turning characteristics. The rear sway bar will increase oversteer and allow the car to turn tighter, while the front sway bar will have the tendency to increase understeer.
$155 shipped!!!
$145 OTD and picked up (includes tax)!!!
$185 installed and OTD!!!
Helix Rear Endlinks - 02+ WRX
-Helix Solid Endlinks are CNC machined from high strength aluminum. This makes an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading. The addition of Helix Solid Endlinks significantly increases cornering response and tightness, regardless of the use of an aftermarket sway bar or not. The use of spherical bearings allows for a much wider range of angular movement and eliminates the squeaking and creaking associated with the deterioration of rubber or urethane bushings. The spherical bearings are teflon coated to prevent dirt and debris from fouling movement.
$79 shipped OR OTD picked up (includes tax)!!!
Helix Rear Endlinks + Cusco 22mm Rear Sway Bar Combo - 02+ WRX
$229 shipped!!!
$219 OTD and picked up (includes tax)!!!
$264 installed and OTD!!!
Cusco 22mm Front Sway Bar - 04+ STi
$155 shipped!!!
$145 OTD picked up (inlcudes tax)!!!
Cusco Pillowball Upper Mounts - 02+ WRX / 04+ STi
-Designed to work with your stock struts.
-The full pillowball design controls unwanted forces under acceleration and braking. Stable steering response in essense and lane changing improved stability over bumps and holds roll in corners. Enables linear handling and keeps you on the record line better. Stability and safety during turn-ins and under braking. Camber adjustable by sliding the plate and pillowball sections.
$219 shipped for Front!!!
$219 shipped for Rear!!!
$419 shipped for Both!!!
*Please add $150 for installation
Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi
-By reducing flex found in the stock mounts, these mounts will dramatically decrease engine and tranny movement.
$250 shipped!!!
$260 OTD and picked up (includes tax)!!!
$360 installed and OTD!!!
Cusco Shifter Bushings - 02+ WRX
-The Cusco Shifter Bushing is designed to replace the soft rubber bushing found at the anchor point of your shifter assembly. This upgraded bushing greatly improves the feel of the shifter by eliminating that spongy feel you get when changing gears.
$37 shipped or OTD picked up (inlcudes tax)!!!
$67 installed and OTD!!!
Thanks,
Geoff
510-783-5300
geoff@gruppe-s.com
$155 shipped!!!
$229 shipped!!!
$155 shipped!!!
$250 shipped!!!
Thanks,
Geoff
510-783-5300
geoff@gruppe-s.com
Originally Posted by firebert
Do you guys take special cusco orders for other cars if I supply the parts no.?
Originally Posted by bpang1
These the shipped prices for Hawaii?
Yes, the typical Hawaii question
Originally Posted by dunnojack
they actually have the shifter bushing for the 6 speed now?
Thanks,
Geoff
Originally Posted by robsrex
Is this deal still on? I'd like the endlinks and rear sway for an 05 WRX. Shipped to 95632
Please send payment using Paypal to sales@gruppe-s.com
Thanks,
Preston
gruppe-s
03-20-2006 03:14 PM
gruppe-s
03-17-2006 03:20 PM
gruppe-s
Engine and Drivetrain
03-13-2006 05:23 PM
