Gruppe-S June Specials ! JDM Motors, Turbos, Exhausts and MORE !
Forrester FXT EJ25 Engine with the cam sensor adapter
$2999 + shipping
Qty 5
-Less than 1000KM!!
-2.5 Liter, AVCS, etc.
-Guys this is essentially a NEW USDM EJ25 STI engine, minus the red intake manifold. The real difference between the FXT and the USDM STI is tuning, turbo size, and intercooler size.
-Long Block includes all pumps, sensors, intake manifold etc
-We will even throw in a USDM STi red intake manifold FREE
Here's a dyno chart with the FXT motor with a VF30 on 91 octane.
Rare STi S202 Oil Cooler ! !
$1799 shipped ! IN STOCK READY TO SHIP !
- Longer engine life
- Reduced heat load on engine and radiator
- Increased oil system capacity
- Lower under-hood temperatures and more!
Wiseco Forged Piston Kits for EJ257 engine
$519 Shipped!
The weakest link in the USDM STI (EJ257) engine is it's hyper-cast pistons. We highly recommend the use of race-spec forged pistons for any application over 400whp. We are offering the race-proven Wiseco EJ257 fully forged pistons as an upgrade for high horsepower applications. These pistons are 0.5mm overbore, are perfect for who have experienced engine failure and need to rehone their cylinder walls. Furthermore, the slight over bore increases displacement, thus resulting in increased power over the stock bore.
Rings and wrist pins are included with each piston kit. Each piston kit is 4x pistons. Installation service available.
Specs: 100mm Bore, +.020 Oversize, Stroke: 3.110,
Rod length: 5.137, Comp Height: 1.209. Head CC: 50,
Comp Ratio: 8.5:1
ARP Head Studs - 02+ WRX
$185 Shipped!
There are many important reasons to use ARP® main stud kits, including the elimination of main cap walk and fretting, as well as protecting the threads in your engine block.
The studs are manufactured from 8740 chrome moly steel, heat-treated in-house to 190,000 psi tensile strength, and precision J-form threads rolled after heat-treat to create a fastener that has threads 1000% stronger than others.
JDM heads ! !
$1499 + Shipping
Hey guys,
We received some JDM heads that has had an advanced type of knock-detection device installed on these before. The heads have been pre-drilled so that a knock sensor can be installed directly into the combustion chamber. You can plug these wholes with a screw or install your own sensors. We’re not sure what type of sensors were used.
The heads feature big-port JDM heads, V7 high lift cam-shafts, and JDM STI valve-train. These heads are good for revving up to 8500 RPM and are perfectly suited for larger turbo applications do to the more aggressive duration and high rev capability.
NOTE: The heads must be inspected and all bolts RE-TORQUED to specifications before installation.
2003 Legacy H6 (that's right 6-cylinder) engine!
$1699 + shipping ! IN STOCK READY TO SHIP !
QTY: 7
-Less than 500 miles
-Great for project cars are sandrails
-Rumor has it JUN Japan is currently using this type engine for a 800whp car
JDM WRX motor
$1599 + shipping
Qty 5
-Less than 1000KM!!
-2.0 Liter, AVCS, JDM Motor
-Higher compression than USDM motor
-no injectors/turbo/intercooler
-This motor features more aggressive AVCS cams and higher compression. With a JDM ECU - YOU WILL MAKE MORE POWER!!
In stock, ready to ship !
Brand new JDM V7 Subaru ECU
$795 shipped !
Features:
*AVCS - Active Valve Control System
*Drive by cable
*Higher redline
*Direct drop in for WRX
Brand new VF39 turbo (Stock USDM STi turbo)
$749 shipped
Qty 2
Used VF37 twinscroll turbo - used less than 500km
$999 shipped
Qty 1
Walbro 255 lph Fuel Pump - w/ 02+ WRX Setup Kit
$100 shipped[/b]
PLX M300 Wideband Sensor
$349 shipped[/b]
Affordable, accurate, compact, feature packed, and simple to use are only a few words that describe our M-Series Wideband Oxygen Sensor Controllers.
The M-300 continuously updates the corresponding air/fuel ratio 10 times per second (10Hz) on its integrated 4 digit digital display. If the air/fuel ratio is measured below 10:1, the LED displays "rich," and if the air/fuel ratio is measured above 20:1, the LED displays "lean". The LED display is visible even in bright sunlight conditions.
HKS Carbon-Ti - 02+ WRX
$739 shipped !
Piping Style: 75mm Stainless Mandrel Bent, Polished
Tip Type: 120mm Straight Cut
Resonator: One
Silencer: No
HKS Hiper - 02+ WRX
$519 shipped !
Piping Style: 75mm Stainless Mandrel Bent, Coated
Resonator: One
Silencer: No
A'Pexi N1 - 02+ WRX
$449 shipped !
Piping Style: AVG 75mm Stainless Mandrel Bent, Coated
Resonator: One
Silencer: Not Included
A'Pexi GT Spec - 02+ WRX
$549 shipped !
Piping Style: AVG 80mm Stainless Mandrel Bent, Polished
Resonator: One
Silencer: Yes
GReddy EVO2 - 02+ WRX
$585 shipped !
The Greddy EVO2 exhaust for the Subaru WRX is one of the most quiet exhaust systems on the market. Designed after the very popular discontinued GReddy EVO catback. All while maintaining a excellent standard in quality. Made from Full Stainless Steel.
Piping Style: 80mm Stainless Mandrel Bent, Coated
Tip Type: 115mm Straight Cut
Resonator: One
Silencer: No
GReddy SP2 - 02+ WRX
$539 shipped !
Piping Style: 80mm Stainless Mandrel Bent, Polished
Tip Type: 110mm Straight Cut
Resonator: One
Silencer: No
Blitz NUR Spec Racing - 02+ WRX
$589 shipped !
Resonator: One
Silencer: Available
Gruppe-S Light Weight Bumper Beam - 02+ WRX
$99.00 + Shipping!!!
We just installed a new bumper beam which we are sourcing from a manufacturer that is making this beam for their intercooler kits. This bumper beam is a direct bolt in for the 02-05 WRX's and 04+ STi. Built from SS304 stainless steel and painted black, the use of this beam saves a whopping 14 LBS off the factory beam!!
Designed to be used with larger intercoolers and oil cooler kits (check fitment first - does not fit all intercoolers w/o cutting), this beam is great for those of you looking for significant weight savings, ease of installation, and chassis rigidity at a great price.
Weighs only 14 lbs as opposed to stock 28.6 lbs.
Koyo Aluminum Radiator for 03-04 WRX/STi
$435 shipped !
~ Koyo Radiator are fully polished to a mirror finish
~ Koyo Radiators provide 20% to 30% more cooling than standard radiators
~ Handles high revving, high performance motors
~ Made from aircraft quality aluminum and Heli-arc welded, cores are NOCOLOK-brazed
GReddy V-SPL FMIC - 02+ WRX
$875 shipped !
Dimensions: 240mm x 600mm x 76mm
Design: Bar & Plate
The Greddy V-SPL FMIC is a good solution for high power applications where the stock TMIC is simply not enough and where top mount heat-soaking is an issue. The Greddy FMIC routes piping over the engine bay. Foglight removal is required for 02-03 models. Cutting of the bumper beam is required
STi Engine Mounts (Pair) - 02+ WRX
$110 shipped !
The STI "Group-N" Engine Mounts are designed to reduce excessive motion of your motor during hard acceleration, deceleration, and cornering.
This is done by increasing material stiffness over your stock engine mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine.
STi Pitch Stop Mount - 02+ WRX
$55 shipped !
The STI "Group-N" pitch stop is designed to reduce forward and aft motion of your motor during hard acceleration and deceleration. This is done by increasing material stiffness over your stock pitch stop.
By decreasing forward and aft motion, more energy is focused to the drivetrain rather than shifting the engine.
STi Radiator Cap - 02+ WRX
$50 shipped !
STi radiator cap increases cooling system pressure to 1.3bar effectively raising the maximum operating temperature. Prevents boilover and coolant loss under the extreme operating conditions of race and rally.
Also improves cooling system efficiency.
Tein Hood Damper for 02-05 WRX/STi only
$135 shipped !
Tein Bonnet (hood) Damper is designed to be lightweight and compact. The main body of the damper only weighs 200g and the extension that adjust the full-open angle of the hood is made of Aluminum, the product is amazingly lightweight even with all parts/components attached.
Gruppe-S Light Weight Pulley - 02-05 WRX/STi
$89 shipped!
~The Gruppe-S Light weight pulley is designed to replace the excessively heavy factory pulley. CAD Designed and CNC precision cut, our pulley weighs in at 1.2 lbs a huge rotational mass savings over the factory pulley.
~The addition of a lightened pulley great improves engine response and allows for a faster rev. Greater mid-range power can also be achieved with proper tuning.
~Our lightened pulley is not under-driven to insure maximum connectivity of belts and components.
~Anodized red, the Gruppe-S pulley will out last, provide increased performance versus, and look flashier than the factory pulley. Plus it is easily installed.
Regards,
Preston
Gruppe-S Engineering
29150 Simms Ct.
Hayward CA 94544
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXXX
sales rep: Preston
Price including shipping: $XXXX
Shipping address.
Originally Posted by PSI-PWR
preston,
what would be the cost on the jdm motor + v7 ecu to 96776? also would the usdm intercooler, turbo, and injectors work on this motor?
thanks.
thanks.
Yes, the USDM TMIC, turbo & injectors will work.
Preston
gruppe-s
Engine and Drivetrain
01-24-2006 05:04 PM
gruppe-s
07-06-2005 05:48 PM
