APs with FREE OVERNIGHT, Cusco, Blitz, Apexi and more...
Former Sponsor
Car Info: WRX, EVO, MSP3
Items are IN STOCK!! Call or PM for best pricing
Cusco Engine/Tranny Mount Kit $250
Specially designed for Subaru, these mounts are completely new. No inserts here, just complete mounts. Perfect for those customers looking to reduce engine movement.
TiTek Catless Downpipe $225
TiTek Innovations fully polished stainless steel downpipe for the 02-06 WRX / STI are offered with a straight flow design through our smooth bellmouth transitioning to our full 3” mandrel bent finishing. This downpipe will help increase horsepower by maximizing exhaust flow efficiency. This item is an easy bolt-on upgrade for stock and upgrade turbochargers for horsepower gains.*
*Recommended purchase: 02-03(may not be necessary) or 04+ Titek CEL Fix Kit. Includes all necessary hardware (gaskets, nuts, bolts).
TiTek Catted Downpipe $407
TiTek Innovations fully polished stainless steel downpipe for the 02-06 WRX / STI are also offered with a 150 cell catalytic design that is 100% brazed for structural integrity. The downpipe utilizes our smooth bellmouth transitioning to our full 3” mandrel bent finishing. This downpipe will help increase horsepower by maximizing exhaust flow efficiency. This item is an easy bolt-on upgrade for stock and upgrade turbochargers for horsepower gains.*
TiTek Up-Pipe with Flex Joint $150
TiTek Innovations polished uppipe is made of SUS304 stainless just like our downpipes and have increased rigidity through the flex joint, which also aids for a much easier install. This piece is precisely tig welded with an EGT sensor bung. This uppipe will help increase in a quicker response for turbo spooling and increased horsepower throughout the power band. Includes all necessary hardware (gaskets, nuts, bolts).
HKS SSQ BOV – 02+ WRX $295
HKS Super Sequential Blowoff Valves (SSQV) are dual stage pull type relief valves that by design do not leak under high boost conditions or under idle vacuum and is actuated by pressure alterations to ensure a quick primary and secondary valve response.
Cobb AP V2 $695 FREE OVERNIGHT SHIPPING The AccessPORT's features include:
» On-the-fly map switching
» Monitor vehicle sensor data and display in analog or digital format
» Vibrant color graphic display with First-Ever full 260,000 color OLED, high-resolution screen
» Read/Clear engine trouble codes
» Preloaded with performance, economy and convenience maps
» Update via the Internet
» Measure 0-60 and ¼ mile times
» Adjustable on-screen Shift Light functionality
» Estimates horsepower and torque
» Displays current and averaged fuel economy
» Drag race simulation with reaction time and “time slip” data
» Built in on-screen help mode function
» Multi-Language support
» RoHS compliant (Lead Free design)
» Custom performance tuning for your specific vehicle and modifications as provided by an authorized AccessPORT ProTUNER center, or upgrade to the StreetTUNER software package for do-it-yourself tuning
Note: For use on North American ECU's only!
Apexi Turbo Timer (Silver) $99
The Apex Auto Timer allows the vehicle to idle for a preset amount of time after the ignition key has been removed. In turbocharged vehicles this prevents hot oil in the engine from coking up in the lines. Hard driving can raise engine oil temperatures to dangerously high levels. Proper cool down is essential for a healthy turbo and engine.
**Harness required at additional cost.
Blitz DTT DC 2 (Silver) $110
The BLITZ DTT (Dual Turbo Timer) DCll is a one of a kind item. This is the only turbo tiimer in the world that incorporates a turbo timer with a boost gauge. The digital boost display can read up to 2.5hkpa (36.75psi) and also includes a digital boost peak hold. This unit also features the two-piece design that allows the user to virtually mount the turbo timer anywhere in the vehicle.
Thanks,
Greg
Or shop at our online store:
http://www.gstmotorsports.com/store/
Thanks,
Greg
maperformance
Tuning, Services, and Installs
147
02-01-2010 08:00 AM
FLIWRX
Engine and Drivetrain
06-14-2007 03:17 PM
FLIWRX
04-30-2007 11:26 AM
GST Motorsports
02-07-2007 08:45 PM
FLIWRX
01-31-2007 10:50 AM
