ACT Street Disc & Heavy Duty Pressure Plate Clutch Kit Subaru Impreza WRX / STi $999!
Former Sponsor
Car Info: Sti, Evo 2003+
WRX: Torque Capacity: 411 ft/lbs
STi: Torque Capacity: 475 ft/lbs.
Increase Clamping Force: 32%
Advanced Clutch Technology Heavy Duty Pressure Plates provide increased torque capacity, durability, and extended clutch life. What makes ACT Pressure Plates the highest standard in the industry? First, ACT manufacturing always begins with new units. ACT Pressure Plates are not rebuilt from worn out parts. Second, pressure is increased the right way. Altering the geometry alone is not enough. Instead, ACT engineers a stronger diaphragm. ACT diaphragms are heat-treated using an exclusive 3-stage process and the release bearing contact area is hardened to reduce wear. Third, ACT designs the pressure and release travel of the unit to be in the optimum working range. Finally, ACT assures consistency and precision by using proven assembly procedures. Every unit ACT produces is accurately balanced and tested. No guesswork, no hype, only proven engineering and calculated results for every ACT Heavy Duty.
Increased Torque Capacity
Extended Clutch Life
Stronger Heat-Treated Diaphragm
Hardened Release Bearing Contact Area
Accurately Balanced & Tested
$999 INSTALLED TAX INCLUDED
INCLUDES YOUR CHOICE OF ACT OR CRUCIAL RACING FLWYHEEL
![SHOCKED](https://www.i-club.com/forums/images/smilies/SHOCKED.gif)
dysfunctnl doll
Hawaii Classifieds
27
11-22-2013 02:39 PM
John OBrien
Vendor Group Buys/Specials
04-28-2009 07:05 PM
tom1208
01-02-2007 06:02 PM
tom1208
08-03-2006 04:54 PM
