8cm TD06H FP20G
Former Sponsor
Car Info: WRX, EVO, MSP3
8cm TD06H FP20G
We have 1 Brand New from Forced Performance 8cm TD06H FP20G.
This turbo comes with all water lines as well as oil drain tube with gasket BOLTED ON. This turbo has also been fully ported by FP. It also comes with the 8cm hotside which is perfectly matched with any 2.5L Subaru Engine.
The 8cm Hotside will not increase Lag substantially (maybe 100-200 rpm) but will increase top end holding power. The 20G with TD06H is a perfect match for the 2.5L Subaru's for a daily driver setup. PSI and flow rates with proper tuning will keep your stock motor running for a long time. Turbo is capable of low 12 second passes on pump gas and is a wonderful turbo for autocross and track cars.
Forced Performance currently has a 2-4 week lead time on these turbos but why wait. Buy directly from us and get it NOW.
The price for this turbo is $1265.00 plus shipping (and tax if in CA). If you need a stainless steel oil feed line, we have those as well for an additional $75.00.
jeffparent
03-20-2005 09:05 PM
