2X STi 1.1:1 STi 6 Spds - $3299!!! Exedy Clutch and Flywheel Combo - $649 shipped!
WRX CLUTCH AND FLYWHEEL SPECIAL OF THE WEEK!!!
Exedy Organic Clutch Kit and CCI Flywheel (Stage 1)- 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
-Ideal for VF series, 16g, and 18g turbos.
-Flywheel appears to be identical to ACT Streetlite (same design, material, performance)
$649 Shipped
STi 6 Speeds:
We've got a couple more STi 6 speeds in stock. These ones are actually unique because they have 1.1:1 center diffs in them. This means that they can drop into any WRX and won't require a rear 3.9 ring and pinion conversion. This will save you close to $500.
6-Speed STI Transmission with DCCD
-Features 1.1:1 center diff
-Less than 5km miles
-Tore down and inspected
-We've done multiple passes (street driven also!) at over 600HP on these transmissions
-Fits all model year Imprezas, Foresters, Legacy, etc. (requires DCCD controller)
$3299
6-Speed STI Transmission without DCCD (06+)
-Designed specifically for 2006+ Imprezas with ABS speedo sensor (does not have speedo in tranny)
$2999
We also have a kit that provides all the extra parts necessary to install a 6 speed in your WRX. Please ask us about this kit if you decide to purchase a 6 spd. from us.
JDM STi Mounts In Stock Now!!
STi Motor Mounts - $95 Shipped
STi Tranny Mounts - $69 Shipped
STi Pitch Stop Mounts - $45 Shipped
Motor and Tranny Mount Combo - $159 Shipped!
Motor, Tranny and Pitch Stop Mount Combo - $199 Shipped!!
Accessories:
Kartboy Short Shifter and Shifter Bushings Combo
02+ WRX - $119 shipped
04+ STi - $175 shipped
These components replace the stock shift lever and shifter mount bushings in 1998-2005 model year Subaru Impreza vehicles, including the WRX, Outback Sport, Legacy and Forester. Overall shift throw is decreased by 40% while also eliminating excessive play in the system for a more solid gearchange. This provides a noticable difference and a solid feel. Constructed of CNC'd and TIG welded 4130 Cr-Mo steel and 95A durometer polyurethane. Installs with simple mechanic's tools in under 30 minutes.
Goodridge SS Clutchlines - 02+ WRX - $59 shipped
The Goodridge SS Clutchline (teflon coated) will improve the feel of your clutch. The stock line is made of rubber and is prone to flexing under hard use. This translates to soft and inconsistant feel in your clutch. The Goodridge line will insure that your clutch feels consistant and firm, even under extreme use.
JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi - $319 Shipped for 5/6th Gear Conversion
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
Clutch and Flywheel Combos:
As usual, we still have the best pricing on ACT and Exedy. If you don't believe us take a look around and compare pricing. Don't be fooled by terms such as Stage 1 or Stage 2; make sure you know exactly what you're getting. If you find better pricing, let us know and we'll beat it. If you don't see a particular combo or item you're looking for, please PM us. Chances are we still have it or can get it.
1) Exedy Organic Clutch Kit and ACT Steetlite Flywheel (Stage 1)- 02+ WRX
$750 Shipped
$1175 Installed!!!
2) ACT HD Street Disc Kit and Streetlite Flywheel (Stage 1) - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped
$1100 Installed!!!
3) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped
$1119 Installed!!!
4) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3)- 02+ WRX
-Clamp Load: 2655 lbs/ft.
-Ideal for 20g and GT30r turbos.
$PM FOR BEST PRICE!!!
5) Exedy Twin Plate Clutch/Flywheel Kit (Stage 4)- 02+ WRX
-Clamp Load: 2205 lbs/ft.
1) Exedy Organic Clutch Kit and Steetlite Flywheel (Stage 1) - 04+ STi
-Weight: clutch - 14.3lbs, flywheel - 15.4 lbs.
$925 Shipped!!!
$1350 Installed!!!
2) ACT HD Street Disc Kit and Steetlite Flywheel (Stage 1) - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
3) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
4) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3) - 04+ STi
-Ideal for 20g, FP Green, and GT30r Turbos.
5) Exedy Twin-Plate Clutch/Flywheel Kit (Stage 4) - 04+ STi
-Ideal for FP Red, GT30r, and GT35r Turbos.
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
*CA Residents please include the necessary sales tax (7.25% or 8.75% for Alameda County)
$649 Shipped
STi 6 Speeds:
$3299
$2999
Accessories:
Ratios:
$750 Shipped
$1175 Installed!!!
$649 Shipped
$1100 Installed!!!
$699 Shipped
$1119 Installed!!!
$925 Shipped!!!
$1350 Installed!!!
$855 Shipped!!!
$1275 Installed!!!
$879 Shipped!!!
$1299 Installed!!!
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
gruppe-s
Engine and Drivetrain
03-02-2007 06:23 PM
gruppe-s
08-09-2006 11:55 AM
RavSpec
03-17-2006 08:00 PM
user3913
05-01-2005 09:12 AM
