*** Cosworth *** Wiseco *** Mahle *** APR
Car Info: 2002 WRX
![](http://www.cosworth.com/images/template/cosworth_logo.gif)
![](http://www.cosworth.com/uploads/1143667817150.jpg)
Cosworth Subaru EJ25 High Performance Short Block - $5100.00 shipped
New Subaru EJ25 STI Engine Case, New Subaru STI Forged Crankshaft, Cosworth Forged Connecting Rods
, Cosworth Forged Pistons, Cosworth High Performance Piston Rings, Cosworth Race Spec coated Tri- Metal Bearings
,Balanced and Professionally assembled, Billet Crankshaft optional
![](http://www.cosworth.com/uploads/1143698072150.jpg)
Cosworth Subaru EJ25 (STI) CNC Ported Big Valve Cylinder heads Pr. (KK3670) - $3795.00 shipped
CNC Ported/machine finished ports - New OE Castings, Hand blended finish work, Intake � 22% Increased Flow (max)
Exhaust � 41% Increased Flow (max), 4-angle Inlet Valve job, 3-angle & radiused Exhaust Valve job, Valves are lapped
Back-Cut Inlet Valves, Heads are Ultra Sonic cleaned prior to assembly, Heads are Serialized and sport a machined Cosworth logo
+1mm Stainless Steel Intake Valves (1800 degrees max.), +1mm Inconel Exhaust Valves (2400 degrees max.)
Performance Valve Springs, Titanium Retainers, Hardened Steel Spring Platforms, Knife Edge port divider
![](http://www.cosworth.com/uploads/1132161154150.jpg)
Cosworth EJ257 US Spec Cam Shaft Set - $999 Shipped
Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs or the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new chill cast billet and finished using the same procedures we use in our extreme level race engines. Cosworth camshafts are the perfect compliment to our CNC Ported Big Valve Cylinder heads. Our Subaru EJ25 cams are profiled to increase boost response thereby increasing engine torque and power and are fully compatible with the Subaru STI AVCS. Please download the technical document on the left for camshaft specifications.
![](http://www.cosworth.com/uploads/1145665693150.jpg)
Coswroth Subaru EJ20/25 Oil Pump - $235.00 shipped
Designed to improve the oiling on modified engines. Each pump is disassembled and inspected. Oil galleys are then honed to ensure unobstructed flow. We then incorporate a modified pressure relief valve to maintain pressure stability throughout the rpm range. Note: Flow rate is unchanged. This is an essential item on any high performance engine.
![](http://www.cosworth.com/uploads/1143667221150.jpg)
Cosworth Subaru EJ20/EJ25 Billet Timing Belt guide - $49.00 shipped
Prevents timing belt from skipping at high rpms
Car Info: 2002 WRX
![](http://www.ravspeconline.com/shop/catalog/images/mahle-piston.jpg)
MAHLE Piston and Ring Set ** top and side coating to reduce friction and noises
********** AVAILABLE APPLICATION **********
- WRX EJ207 92.0 mm Stock Bore - $499.99 shipped
- WRX EJ207 92.5 mm (0.5 mm / .020) Over Bore - $499.99 shipped
- WRX EJ207 93.0 mm (1.0 mm / .040) Over Bore - $499.99 shipped
- STI EJ257 99.0 mm Stock Bore For EJ257 - $499.99 shipped
- STI EJ257 100.0 mm (0.5mm / .020) Over Bore - $499.99 shipped
![](http://ravspeconline.com/shop/catalog/images/wiseco-piston.jpg)
For over 60 years Wiseco has been manufacturing the finest aftermarket forged pistons & performance parts for the snowmobile, motorcycle, ATV, personal watercraft, outboard marine, karting and automotive markets.
1. Valve Pocket designs that allow maximum flow around valve, also allowing oversized valves and high lift cams to be utilized.
2. 2618 extruded material forged for the maximum strength available.
3. High quality piston rings featuring alloy steel contrusction on top ring, cast iron taper faced 2nd, and 3PC oil assembly utilizing atainless expander and carbon steel rails.
4. Wrist Pins constructed of chrome moly steel material for ultimate in strength.
5. No wait time, most piston are available in stock.
ARP Head Studs Kit For EJ207/EJ257 Engine - $219.99 shipped
![](http://www.ravspeconline.com/shop/catalog/images/arp-head-studs.jpg)
![](http://www.ravspeconline.com/shop/catalog/images/cr-rods.jpg)
Carrillo Forged Rods For EJ20/EJ257 Block- Starting @ $782.00 shipped
Eagle Forged Rods For EJ20/EJ257 Block- $399.99 shipped
Scat Forged Connecting Rods For EJ20/EJ257 Block- $399.99 shipped
![](http://ravspeconline.com/shop/catalog/images/eaglerod.jpg)
