tranny swap 6 speed (DCCD vs non-DCCD?)
Car Info: 02 WRX and 90 CRX
tranny swap 6 speed
Yes i am still new to this but i heard there is a non DCCD 6 speed tranny and there is a DCCD 6 speed tranny is this true. I wanna put the 6 speed into my 02 WRX but dont know what tranny to do with if so. If someone can help me out and tell me what the difference is between both of thm that will be helpful thanks guys and girls if you can help me out.
MIKE
MIKE
The DCCD 6-MT will act like a rear wheel drive car without the DCCD controller, or when the DCCD control is set in the furthest rear setting. You would not want to have the DCCD control set anywhere but all the way back on dry roads or day to day driving (similar to having a 4wd truck in 4wd all the time). The good part is when you accelerate straight, have the DCCD engaged you get the benefit of awd. This is what I have in my '02 WRX.
As far as I know the non DCCD 6-MT has some kind of limited slip center diff. It seems to me that this would act similar to the way a stock WRX acts. This is the way I wanted to go and wish I would have gone, but being basically a rwd car can be fun too.
Good luck with your swap. PM me if you have questions if you want.
BTW do you have your 3.90 ring and pinion for the rear diff? and the new driveshaft?
-Eric
-Eric
Witch of the the trannies dont come with the DCCD. I haven't started to get anything yet just doing all my research first before i start to put one in. Well if any of you guys and gals can help me out thanks.
MIKE
MIKE
Car Info: A couple wagons and one weird S2K Guy...
You can get both the version 7 and 8 JDM STI 6 speeds in a non-DCCD transmission. You can also find verson 6 STI RA 5 speeds with DCCD. It pretty much all comes down to what you want.
Richard
Subaru OEM Parts For Sale
07-23-2011 09:00 AM
tbonetristy
09-07-2006 02:06 PM
