Stumped after clutch replacement (engine won't turn over by starter or by hand)
Car Info: 04 WRX STi
I have recently installed an ACT 6-puck clutch and pressure plate(with new pilot bushing and throwout bearing) into my 04 STi. I double checked all my connections and attempted to start the vehicle. It doesn't, it just clicks like the starter is bad or battery is dying. I pulled the starter and had it tested, it works fine. I have checked all my connections and grounds multiple times. I then proceeded to turn the engine by hand by putting a 22mil socket on the main pulley and the engine won't turn. I can move the car in neutral, but not in any gear.
The only thing I can think of is if I bound the flywheel up when I mated the tranny. The flywheel was spinning freely when I torqued down the flywheel(it was resurfaced) and the pressure plate. I am going to start to remove the tranny again tomorrow and retrace my steps. Any input/advice will be greatly appreciated.
Thanks in advance.
Thanks in advance.
When I turn the key to the ignition to the on position everything on the car turns on including the headlights. I even tried to jump start it. I will take the battery to get tested today just in case.
Thanks.
Thanks.
I had the battery tested and it checked out fine. I beginning to wonder if it is possible to push out the pilot bearing and having it wedge in the flywheel teeth.
Does anyone know if this is possible?
SlickmisterN
03-15-2019 04:06 PM
tofuman
12-04-2008 12:54 AM
Laggrider
12-22-2004 12:12 AM
