Spare Causes Front Diff Failure?
Old 03-13-2004, 07:45 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Maybe you lost a wheel bearing?
mexicanpizza is offline
Old 03-16-2004, 03:03 PM
WRXnifect's Avatar
Car Info: 03 WRX Wagon
quote "Could it have anything to do with a different outer diameter between left Yokohama and stock spare tire? "
-yes-
you have 3 tires of similar or same circumference and one that is different on an AWD vehicle, then you drove on the freeway for 30 miles at 70 mph. You may have cooked the front diff and/or the center diff. That's why in the owners manual they tell you to flatbed the car (and my salesman when I bought mine went into great detail on why not to do this) if you don't have the same size spare. Even the warranty roadside assistance will flatbed your car (if it is still under warranty) if you get a flat
I hope for your sake I am wrong
WRXnifect is offline
Old 03-16-2004, 05:34 PM
meilers's Avatar
I think it is pretty common knowledge that regardless of whether your car is 2WD or AWD, you don't drive more than 50 MPH and longer than 5-10 miles on a donut spare, period. Driving 70 was essentially drivetrain suicide, though this doesn't do much good as hindsight.
Let's hope they warranty your repair. With aftermarket wheels and tires, you may be out of luck.
meilers is offline
Old 03-19-2004, 09:41 PM
meilers's Avatar
<insert sound of Nelson from the Simpsons>
Ha-Ha!
I'm typically not one to laugh at anyone's misfortune, but I just checked my spare and it does say right on the tire to stay under 50 and get off the donut spare ASAP. Live and learn!
meilers is offline
Old 03-20-2004, 03:01 AM
rustokman's Avatar
Car Info: Black 03 WRX
even though it is open, the different diameter wheels will cause the differential to act as if it is turning and if you go over 50 for an extended period of time it will heat the thing up really well and it will fry it. It would be even worse in the rear though. If you get a rear flat, put a front tire on the back and the doughnut if the front and GO SLOW.
rustokman is offline
Old 03-31-2004, 03:26 AM
go go go's Avatar
Car Info: GF8 ver6
225/40/18 is 637mm diameter
205/55/16 is 631.9mm diameter
it's less than 1% difference in diameter though.
I doubt its enough to cause trouble.
but true, shouldnt have gone more than 50mph and shouldn't have driven 30miles
your symptoms seems similar to mine, I broke transmission by running low on oil (didnt notice the leak from transmission).
Maybe you should check transmission fluid.
go go go is offline
Old 03-31-2004, 04:04 PM
scoobsport98's Avatar
Car Info: 98 Impreza Outback Sport
[QUOTE]Originally posted by go go go
[B]225/40/18 is 637mm diameter
It seems to me that the circumference is what we're lookin at... so it's probably closer to 3% difference. Not tryin to split hairs, but 3% is quite a bit more substantial
scoobsport98 is offline
Quick Reply: Spare Causes Front Diff Failure?
