Scrapping sound?! Tranny?
Old 12-22-2005 | 08:41 AM
SubieStylez's Avatar
Car Info: 2001 WRB 2.5RS, Gold Prodrive P1's, Stromung Dual Tip, AEM SRI, Pink "i" fornt badge
I was at DD (Dunkin Donughts, Pigs Palace whatever you want to call it) and while in the drive through over hang, as I pulled up from baseline to about 1900rpm I heard a low but loud enough to notice scraping/squeaking sound. It will only happen in those RPM ranges, I dont know if it could be the tranny or what? It's a 4eat so it's not me on the clutch. At first I thought it was my suspension just being a little creaky because its only about 30 degrees out but it was when I got on the throttle, it made the noise. Anyone know what this could be?
Old 01-11-2006 | 09:02 PM
BuickturboV6's Avatar
OEM or aftermarket Clutch?
The reason I ask, is because I had a Stage II ( Ceramitallic) clutch in my car for a short period of time and occationally it would make "scraping" sound on engagment. Once fully engaged the sound was no longer there.
Old 01-11-2006 | 09:28 PM
SubyN00by's Avatar
ummmm, it's an automatic so no clutch, could it possibly be a loose belt? do you hear it often or was it just this one time?
Old 01-12-2006 | 11:40 AM
projectwrx's Avatar
Car Info: wrx
does this happen when you let off the gas?
plac
08-27-2008 01:34 PM
fishcake
05-06-2008 12:08 AM
SuPraScOObY
10-20-2004 03:21 PM
drewster2002
02-22-2004 05:06 PM
01Impreza
04-16-2003 09:48 PM
Quick Reply: Scrapping sound?! Tranny?
