question about my blown transmission
i launched in first gear around 4500rpm then when i dropped the clutch it lurched foward but after that all i hear is revving after that..it was hard to get out of 1st gear i had to hold the clutch down and take both of my hands and pry it out into neutral..tried to put into 2nd then after that got stuck too...third was ok just a little notchy feeling thru 5th and reverse..but after that, 3rd-5 was hard to get into after a while..WHAT GEARS DID I STRIP GUYS??? OR WAS IT SYNCHROS I BLOWN? although i do hear something loose in my transmission when idling and its loud..thanks..
kevin
kevin
Location: EBAIC- Wondering if I should have taken the blue pill...
Sucks...I just blew my 2nd gear 10 minutes ago. Maybe we can see if we can get a deal at gruppe s to rebuild both of ours? you interested? Please pm me.
similar experience happened to my once...after 20 or so minutes it was--ok again. anyway, just a week ago the 5th gear popped back to neutral...no it doesn't. Hope you have the same luck as i did. I've heard these are very weak when put a lot of stress on them!
does its sound like a bunch of rocks rattling in a coffee can??? if it does its most likely you broke the gears. i know from experience. hope this helps. laters man.
kevin
kevin
