Problems with STi differential!! where can i fix!? :(
Old 05-14-2006, 02:44 AM
sjice's Avatar
Car Info: '13 BRZ - SWP
My 04 STi is okay in Auto, and okay in full rear..
But when i put it in 2nd level (one above full rear) i hear a scraping sound from the front tires.. and as i move up in putting power to front wheels, it gets louder and louder.. and kinda makes clunking sound.
my friend said its something to do with the LSD, that its not catching correctly.. or locking too soon? or maybe even electrical.. (i just installed defi's) i have no clue, but i know it has to do with the front wheels and differential.. if anyone could direct me in a direction it'd be great.. bleh.. this sucks..
plzzzz help me!
sjice
sjice is offline
Old 05-14-2006, 05:12 AM
illogical's Avatar
Car Info: 2004 WRB STi w/ s202 spoiler
What if you disconnect/uninstall the Defi's?
illogical is offline
Old 05-14-2006, 02:00 PM
BoxerRumble's Avatar
Car Info: 2005 STi Silver
Were you moving the dial as you were driving? The manual says to leave the car parked and then adjusting the dials.
BoxerRumble is offline
Old 05-14-2006, 02:16 PM
Admin v2.0
Imprezer's Avatar
Car Info: 02 Black Legacy GT
Double check the gauges installation.
Imprezer is offline
Old 05-14-2006, 03:13 PM
sjice's Avatar
i found out it could possibly be "torque binding?" suppose to be normal on STis?
sjice is offline
Old 05-14-2006, 04:05 PM
Admin v2.0
Imprezer's Avatar
Wait, scraping like your inside wheel is slipping ont he ground? That kind of scraping?
Imprezer is offline
Old 05-14-2006, 04:30 PM
sjice's Avatar
sounds like that.. but i dunno
sjice is offline
Old 05-14-2006, 04:41 PM
Admin v2.0
Imprezer's Avatar
Just have someone look. If your inside wheel is spinning when you turn thats normal.
Imprezer is offline
Old 05-14-2006, 06:05 PM
CreoWRX's Avatar
Car Info: '08 FSXT (Aspen White)
You can adjust the DCCD while you're driving. I did it all the time.
If you're turning the wheel while the clunking sound occurs (and you're in manual mode at any DCCD setting above full-open), then it's due to "torque binding."
More info. here;
http://www.iwsti.com/forums/showthread.php?t=28429
http://www.iwsti.com/forums/showthread.php?t=3761
-Mike-
CreoWRX is offline
Old 05-14-2006, 09:11 PM
04caliwrx's Avatar
Location: on the way to lake tahoe to shread! turbo beast
go to subaru
04caliwrx is offline
Old 05-14-2006, 09:26 PM
wm07's Avatar
Car Info: 04 STi & an autox Lemming
It's normal...
wm07 is offline
Old 05-14-2006, 10:01 PM
Admin v2.0
Imprezer's Avatar
go to subaru
What does this mean? Explain please. Are you trying to be sarcastic? Because if you are, you obviously know nothing about differentials, and therefore, should not be allowed to make silly sarcastic comments about stuff you have no clue about.
sjice, if it still bothers you, I will be happy to give you a ride in my WRX with front and rear CUSCO LSD's. My **** clunks so much it scares all the cats in the neighborhood. After that, you will feel a lot better about your "silly" clunking...
Imprezer is offline
Old 05-15-2006, 01:06 AM
03.23.67 - 06.14.13
ldivinag's Avatar
apparently, non of you ever drove a 4wd truck with a detroit locker... lol... the old style detroits...
ldivinag is offline
Old 05-15-2006, 07:57 AM
wm07's Avatar
man, read your owner's manual, it states there that it's totally normal to have noises for running any settings besides Auto for dccd. don't worry about it.
wm07 is offline
Old 05-28-2006, 06:55 PM
06naSTI's Avatar
Car Info: 2006 Black STI
Yes diff noises are normal.
06naSTI is offline
Quick Reply: Problems with STi differential!! where can i fix!? :(
