Help it wont come loose!!
Car Info: Silver 02 WRX
We have every bolt out og the tranny and the fork retaing rod thingy out but the damn tranny after 6 hours of messing with it wont break loose from the motor. were trying to take it out the bottom to change the clutch which is how i have always done it but i talked to a guy to day who said i have to pull the motor, PLEEZE say it ain't so.
AFAIK...the motor has to move foreward ~2 inches to get things to work...the engine goes foreward...not the trans going back...
Pr0n King
Car Info: Turncoat Turbo
Judicious application of considerable force was required to mate the trans. to the block in my case. I also had to (*cringe*) pull the trans torwards the block the last 1/4" by tightening the engine-to-tranny bolts.
__________________
__________________
Chewwwwy
you need to miake sure all the bolts wil lthread without binding, then just tighten them all equally, like torquing a wheel, and the tranny will suck itsef right onto the engine.
wrx 03i
08-18-2011 06:58 PM
wrx_aaron
03-05-2004 07:03 AM
Ayapon
02-28-2003 04:18 PM
