general tranny questions
Old 04-09-2008 | 10:12 AM
sebastiansally's Avatar
Car Info: WRX SUBARU 06
hi i owned 2006 wrx and i blew up 3rd gear....and i replace em with 2007 2.5i impreza tranny with 3.9 rear diff....and my questions is ...is wrx tranny from 2006 model is stronger than 2.5i trannsmission or 2.5i is a little bit stronger.....and what i mean by stronger is the gear or maybe same display like wrx tranny...ill break down on 3rd gear......so please let me know people thanks....
Old 04-09-2008 | 10:17 AM
nerd's Avatar
Car Info: 06 Audi A3
Tranny questions usualy go to Paul He's an expert.
Old 04-09-2008 | 10:28 AM
u mean DBtuned paul??...
Old 04-09-2008 | 10:38 AM
Irrational X's Avatar
plays well with others
Car Info: your mother crazy
yes
Old 04-09-2008 | 06:03 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
If you broke 3rd gear, you drive the car hard.
Nonturbo gearsets are weaker than turbo gearsets.
So, if you broke a turbo gear, you're going to break a non turbo gear.
Do you still have the WRX gearbox?
If so, bring it by the shop so I can start rebuilding for you.
Old 04-09-2008 | 06:07 PM
LXVTEC's Avatar
Car Info: 1999 Impreza 2.5 RS
Also doesn't the 2.5i tranny have a different center diff gear ratio requiring the rear end to be swapped with a 3.54. As well as the clutch and flywheel.
Old 04-09-2008 | 06:13 PM
well before i had new RA gearset ...than someone want to buy my car so..y should i dump RA gearset if iam goin to sell my car....i sold the RA gearset for 1000$ than the buyer flake out...so yeah ...how much to rebuild anyway??thanks
Old 04-09-2008 | 06:14 PM
well the seller gave me 3.9 rear diff iam not really sure...which one it is
Old 04-24-2008 | 09:51 AM
nicknaz's Avatar
Car Info: 328i
are you making close to 300tq? if so, maybe you should think about dropping $$ on a 6spd or ppg gears
if not maybe you need to revisit your shifting
nickraft14
01-15-2011 09:41 AM
skierdoug13
08-21-2005 02:25 PM
DGibb
05-15-2003 11:15 PM
Quick Reply: general tranny questions
Top
