Drift a WRX! AWD to RWD (conversion) magazine article.
Car Info: Subaru WRX MY02
Drift a WRX! AWD to RWD Sports Compact Car Magazine has an article on it.
Note: Added this line. Drat. I think i put this in the wrong forum. If an admin can put this in the transmission forum instead. Sorry!
Hey guys, I thought I'd share this info. Ever since I came back from the D1 Grand Prix Drift Session down in L.A. I've been amazed at all the cars drifting. Heh. It was my first time and it was pretty darn cool.
Anyways, the April 2004 of Compact Sport Car Magazine showed a modified WRX appears to be a 2002 or 2003. They changed the center differental out to make it an AWD to an RWD.
Heh, I can now drift my wrx Yeah right, ill probably never do it.
Anyways, It mentions locking the central differential is key. Its roughly a "30 minute" job for the average mechanic according to the article. I dont have a scanner but I thought I'd post this up.
And if its an old article, sorry! I thought it was the coolest thing since chocolate ice cream. heh.
They point to a website:www.designcraftfabrication.com
This seems pretty cool.
Be prepared to make adjustments to the suspension after doing such a conversion. By sending 100% of the power to the rear wheels, the car's character will be drastically different, especially on wet ground. I'd consider this mod to be an off-street, competition only.
This isnt true! Cars drifting in the D1 Grand Prix were drifting with sub 200 hp cars. I dont know if the AWD factor will require more hp?
Also isnt it true that those who drift prefer super sticky tires? Drifting with super slick tires would cause uncontrolled slides.
Thats the reason why they were using sticky tires at the D1 GP?
Anyone want to confirm this or deny this? Prove me wrong
Location: Trying to figure out something creative to put her
Car Info: 2005 CGM WRX Wagon
And yes, drifters do prefer sticky tires for their control (but those cars that have sticky tires also have gobs of power - so there is no problem spinning them). I was just stating the very least of what you need to drift a WRX. Ideally you would want 400+ hp to use sticky tires with a WRX. Oh, and you would have to do something about the drivetrain. Sticky tires and 400hp on a stock WRX drivetrain = terrible things
Car Info: 2002 Honda S2000
Well if they could make a system for the wrx to switch from rwd to awd with a flick of a button, I would be all for it, but I don't think i would want to sacrifice my awd forever. I do agree it would be sweet to have a car that can grip and slide.
Hey, If I can do 180s and 360s in my '95 Legacy, what prevents my little 135hp car stock (it's not stock) from drifting? It's all about power and braking. I would assume a good driver knowing the limitations and capabilities of his/her car would be able to drift if they had skill. (FWD isn't too hard, but RWD is way easy. Doesn't take alot of skill to get started.)
Drifting awd is possible its a function of stiff rear swaybars/shocks&springs to keep the rear flat so it slides instead of biting into the pavement. That and major positive camber up front so the car can pivot on the nose with major negative camber and a little toe in the rear for more sliding ability. Thats why drifters kill tires because there using mostly the inside edges of the tires for grip.
