Anyone running two different kinds of fluid?
Old 12-29-2003 | 11:59 AM
wrxn'sx's Avatar
Car Info: 03WRX=sold 08STI=newhotness
I'm thinking of running a syn in the rear diff since its enclosed and seperate from the transmission (read: NO SYNCHROS). Then running the stock fluid in the front, since people are getting problems w/ syn & their synchros.
Old 12-29-2003 | 03:10 PM
highspeed11's Avatar
Car Info: '05 LGT
That's what most people seem to be doing. Although some have been running Redline, and maybe Motul/Neo, with no problem in the transaxle.
Although it is fine running dino in the rear diff.too.
Old 12-30-2003 | 07:23 AM
ride5000's Avatar
if you mean different fluids in the tranny vs. the rear diff, then there's no problem with that.
i use mobil 1 in both, but i "cut" the tranny fluid with 33% pennzoil syncromesh fluid. it eliminates the "grind" issues with slippery synthetic MT fluid.
jm2c
ken
Old 12-30-2003 | 08:21 AM
t-wrexxx's Avatar
The best lube I have heard about for the trans is the Neo Synthetic. I know the rally cars use it, so it has to be good.
Old 01-10-2004 | 02:22 PM
surferdude166's Avatar
Car Info: Impreza WRX
try the royal purple for the front system and the rear diff. I've heard very good things
subaruwrx
07-29-2009 01:39 PM
tamashi523
10-29-2007 09:33 AM
Gixxer750
08-03-2004 12:33 AM
Black Shadow
02-26-2004 10:06 PM
Quick Reply: Anyone running two different kinds of fluid?
