2004 sti transmission?!
Old 01-25-2011 | 04:59 PM
bugeye41510's Avatar
Car Info: EQ tuned bugeye
Question 2004 sti transmission?!
what would be all that i need in order to swap out my 5 spd to a 04 STi 6 spd???? please ! TIA
Old 01-25-2011 | 05:01 PM
04caliwrx's Avatar
trany, axels, F&R diffs, new clutch flywheel, dccd. will cost a lot of $$
Old 01-25-2011 | 05:09 PM
whats the axels, i cant use the same ones 5x100 wrx !?
Old 01-25-2011 | 05:10 PM
johndabrit's Avatar
Da Brit.
tranny alone is 2800-4000
Old 01-25-2011 | 05:18 PM
04caliwrx's Avatar
I know I have a swap, so I know the price and you also might want to bet the sti brembos when your at it!
Old 01-25-2011 | 05:47 PM
LOL_VTEC's Avatar
Car Info: 2018 Tacoma TRD PRO
You can get full swaps for 4-4,500.
Old 01-25-2011 | 06:06 PM
^damn thats bank
Old 01-25-2011 | 06:21 PM
DerekB707's Avatar
Car Info: 07 rs STi swapped Rotated BW S200SX-56
You could go the cheap route too, you have the 3.54 ratio in your R160, Buy an 06 or 07 6MT (the ratio will match your stock R160), and the front axles will mate to it, get an auto drive shaft. You'll be able to run your stock hubs/knuckles/brakes. It won't be as strong this way and unless you get an DCCD controller, the 65% power to the rear might cause the R160 to fail prematurely. You could buy the other stuff as you get money. Just another option.
Do a search on Nasioc, there is a bunch of info on every option you have for this swap.
Old 01-25-2011 | 06:47 PM
LOL_VTEC's Avatar
Built five 5-speed
I'm probably picking up some MFactroy gears in 4-5 months.
Old 01-25-2011 | 07:25 PM
04caliwrx's Avatar
Originally Posted by LOL Vtec
Built five 5-speed
I don't know if this it true but I read of a different forum that M factor went under... I could be wron but thats what I read
Old 01-25-2011 | 07:32 PM
LOL_VTEC's Avatar
The site is still up. Huh
ddavis
03-31-2013 11:00 AM
MindzeyeWRX02
01-06-2010 02:35 AM
gordata
Subaru OEM Parts For Sale
09-18-2007 10:38 PM
DesolationSuby
04-22-2007 05:25 PM
Quick Reply: 2004 sti transmission?!
