2002 WRX squealing (when turning wheel left or right)
Car Info: 2002 MBP WRX
Hey guys,
As the title states, my car is squealing. It happens whenever I turn the wheel, or when I first start the car. I was hoping it was just my belts (which shouldn't squeel since they were replaced just 5,000 miles ago) but would it be the power steering?
I noticed sometimes trying to steer while it squeals is hard and jerks a lot.
Another thing that "squeals" is my driver and passenger front windows. Whenever I roll them down or up there's this annoying squeal. Anybody know what's causing it and how to fix it?
Thanks!
Kevin
Thanks!
Kevin
Car Info: '02 WRX wagon
im having the same problem with my window. but i got my windows tinted recently, and haven't heard any problems. not sure if that helps you at all, but if you were interested in getting tints, that could be a "two birds one stone" task.
you need new ps belt
and the skraping noise from the window is the felt skrapers in the door full of dirt . ive tried to clean them but found the best results with new ones. 2 normal problems
As for the windows, where can I find the felt that will eliminate that annoying squeal? I noticed that there's a line down the middle on both sides that looks like the guide for the window as well.
that dark dirt might be from the acual belt from it slipping, so you might want to replace it or buy an extra one and throw it in your trunk just incase that belt on there breaks. Also check your pullies for wear. That might also cause the sound.
Some folks claim that silicone lube causes deterioration of rubber or plastic but I haven't noticed this if a small amount is used. My front windows used to squeal badly but no longer.
subiescottwrx
08-31-2007 11:14 AM
