06 STI transmission oil leak
Car Info: 2006 STI
I've had the car 3 weeks, and I've already been to two incompetent dealers about a transmission oil leak. The oil appears to be coming from a steel hose fitting, connecting the back of the transmission to the front differential, on the driver's side of the car. The hose has two copper washers on a hollowed bolt at each end. After the dealers both just kept cranking on the bolt, I replaced the washers, and it's still leaking. Does anyone know of a technical service bulliten for this problem? Are there any TSBs for oil leaks on this car?
salvator_rizzo
07-10-2009 04:10 PM
yzercyber
03-02-2008 06:02 PM
bigdaddy
07-10-2003 12:09 PM
Zoeb2s
12-30-2002 10:43 AM
