weird fan cycling and cel flashing someone help
Former Sponsor
Location: 865 A Sweetser Ave.Novato, CA (new shop smell too)
Car Info: MY04 STi some call it a race car
Well it sounds like you may have the Test Mode connectors plugged in. They are the two green connectors under the dash near/above the OBD-II connector. When plugged in, the fans will cycle and the CEL will blink rapidly, but the ECU turning on/off sounds like it could be something different. Make sure you have your power wires correct, such as from the main relay, battery, and ignition. Hope this helps.
-Adam
adam@licmotorsports.com
-Adam
Flauntinghippo
08-26-2005 07:49 PM
mrmodex
06-18-2004 09:06 AM
superfly
02-18-2004 09:04 PM
