ver 7 sti gearbox swap into my02 wrx
i have recently purchased a ver 7 gearbox and have been reading about the swap. I read somewhere that you have to convert the clutch from push type to pull. I was wondering how hard this was. Any info on this would be appreciated.
Thanks,
Rance
Thanks,
Rance
Originally Posted by international B
you do have to change the rear diff to a 3.90 ratio tho...
JDM V7 box will require JDM rear diff
EU V7 box has different ratios to that of the JDM one.
Best to check which you have.
like the boys above said, double check your trannies country of origin....some Euro trannies came with 3.54 gears like the USDM WRX, so all you'd have to do is get a shorter prop shaft.....If it's a JDM tranny than you must use an STi rear end, including hubs, axles, e-brake shoes, rotors, backing plates, 2 pots, etc.....or you can cheat and use an older 3.9 diff from another Subaru......
good luck,
good luck,
anthonys192
01-20-2014 04:41 PM
anthonys192
11-21-2013 11:10 AM
anthonys192
11-20-2013 11:45 PM
harpoonflyby
01-26-2006 11:48 AM
scoobynutter
12-22-2005 09:51 AM
