Need help with cam sensors in STI swap
Old 07-13-2012 | 11:09 PM
youpers's Avatar
Car Info: LGT STI
I swaped a 06 STI into my older LGT, which I use to have an older V7 STI installed in. The problem I am coming up against is that the cam sensors on the new heads have a three wire connection, whereas my harness has plugs for two wire cam sensors. The good news is that I have a Hydra ECU, so I could add new plugs in the harness for the new cam sensors.
Does anyone know if this is possible or how to wire it... Or if I should just get the Cosworth cam sensor brackets, and if so can I use the 06 STI cam gears? I would like to avoid spending $160 for brackets if I can.
PS: I already have the AVCS wired up and working just fine.
Old 07-15-2012 | 10:59 AM
youpers's Avatar
Car Info: LGT STI
Anyone ever had any success running the: Honeywell GT101 Single Channel Hall Effect Sensor (Wheel Speed, RPM trigger etc) (Honeywell GT101)
H_wells3000
03-22-2015 04:00 PM
Krinkov
02-22-2011 12:48 PM
medicSTi
09-25-2007 11:29 PM
mmboost
08-23-2004 07:58 PM
BluSubaru007
06-29-2003 12:27 AM
Quick Reply: Need help with cam sensors in STI swap
