JDM STI RA Spec C Engine
Old 10-30-2004 | 01:24 AM
XkrazyAsianX's Avatar
Car Info: SGM 135i
yea .. well .. im here in reno right now for halloween, i just check out justin from japanese imort's R33 GT-ST RWD skyline... that ****'s ***ing pimp, *** imports getting another R33 like that ... and justin said he might trade straight off with my rex ... iono buh this **** is ***ing tempting. i think i might do the trade .. what you guys think? .. the R33 is GT-ST also, one of 72 in the U.S. and i have a 04 rex with 12000 miles with helix up and down pipe, perrin crank pulley and borla hush catback. what you guys think about that? the R33 im getting is black and RWD, so what you guys think about that?
Old 10-31-2004 | 09:47 PM
Car Info: SGM 135i
o and here's a pic of the car that i will be getting if i trade the rex.
... um can't figure out how to post the pix so here's the url for the pix .
http://www.japimportsusa.com/Nissan.html it should be the 5th car down, listed R33 GTS-T Series II.
Old 10-31-2004 | 09:59 PM
Car Info: SGM 135i
and the reason why he's doing it is because he needs a back up for the shop's mirage that's being converted to a EVO 5 to be rally prepped.
Old 11-04-2004 | 08:03 AM
Car Info: SGM 135i
... okay scratch the skyline idea, mix fuel 95 octane = 80 bucks a tank. no no no. can't have that in cali >< plus it will be hard to find someone to tune the ecu. maybe i'll make it a mid life crisis car. i'll get it when im 35
Old 11-04-2004 | 09:28 PM
EJ20K's Avatar
Originally Posted by Imprezer
You cannot be referring to the New Age STi Impreza's by "Versions" as there are not any.
Typically, when people say Version 7, that is the first AND second year of the New Age STi.
Those were released as model year 2001 and 2002. Or, MY01 and MY02.
MY01 STi's are properly called GDB-A or GDB revision A.
MY02 STi's are properly called GDB-B or GDB revision B.
Both of those had regular turbos (non-twin scroll).
Spec C was not offered in MY01 and was offered in MY02 as STi Type RA Spec C, STi Limited and STi S202. While the last two were not called Spec C, they had same Spec C motor. There were few differences like ECU's, accessories and turbo's. Those are the golden non-twin scroll forged piston Spec C motors.
Also the EURO and OZ spec STi's were released with the same forged pistons mentioned above, the rods look identical, dunno about the crank. Have heard the rumour that the latest MY05 spec C and spec C RA have gone back to forged pistons ..... is this actually true ?
Carlos
Old 11-07-2004 | 08:33 PM
Car Info: SGM 135i
lol, now that's asking for 2 much. and as for jspec, the r33 is a GTS-T type M with a rb26, single turbo, and rwd ... there's only 71 in the us . so it is very different compared to japan. im not even doing it anymore cause of the gas and registration ><
Old 03-05-2005 | 02:40 PM
Car Info: SGM 135i
hmm. another question out to imprezer, what motor would you recommend to swap into a 04 wrx. im thinking of the complete swap with motor, ecu, and tranny. im thinking of getting around 280-300 whp after the swap, do you think that can be easily achieved?
Old 03-07-2005 | 07:56 PM
ac64drew's Avatar
Post
I know this is not directed to me but theres..so many different ways to achieve those number...you have to look at your budget..I would definitely read up on the threads and do some searches.......................................... .........................
Old 03-08-2005 | 12:08 AM
Car Info: SGM 135i
i understand, vf34 with linksys, sti short block, etc. buh i was told it's better to go with the jdm motor by MPJ also i can't deny the 8k redline .
Old 03-08-2005 | 12:18 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
I prefer the pre-twin scroll Spec C motors. Get that complete with ECU. 6MT is great, but that is a lot of $ to shell out at once.
Also, another great motor is a USDM 2.5L shortblock w/ JDM Spec C heads. That hybrid is very capable of making near 300hp on pump with over 300 ft.lbs of torque.
Old 03-08-2005 | 01:58 PM
Car Info: SGM 135i
with the spec c heads, that will give me the 8k redline correct?
Old 03-08-2005 | 04:05 PM
dwrx04's Avatar
Car Info: 98 2.5RS
Would you use the USDM STi wiring harness and wire the avcs in to that or just use the JDM wiring harness?
Quick Reply: JDM STI RA Spec C Engine
