2.5i to STi shortblock swap Questions
Car Info: 2006 Impreza 2.5i
I plan on swapping an IAG stage 2 STi shortblock in place of my 2.5i and using the SOHC heads for boost. Going to use an EL header and a grimmspeed up pipe with a FMIC kit. OEM STi oil lines. still undecided on the turbo.
I have been doing alot of research and am needing help with one thing. The crossmember. A wrx crossmember would work but requires shimming the control arms (would rather not do). And the 1991-1994 turbo legacy should be a direct swap with no modification. Or i could notch my own.
Does anyone know where to find a damn 91-94 turbo legacy xmember?
Is notching the xmember i have already really that hard to do?
Any and all advice regarding anything about the swap is also welcome.
krazy9er
07-28-2014 07:37 PM
NorcalCarbonWRX
03-18-2010 01:11 AM
