More fuel efficient: Higher RPM less petal or lower RPM more petal?
Old 06-09-2006 | 12:30 AM
Boost Addict's Avatar
I said you rock my socks, damn it... Have you NOTHING to say to that?!?!??
Old 06-09-2006 | 09:57 AM
chimchimm5's Avatar
Car Info: 2011 WRX hatch gray
Sorry... thanks... FWIW I smiled but didn't post. My bad, I just came from NASIOC.
Old 06-09-2006 | 04:00 PM
Haha, I'm just eff-in' around... Seriously though, you've made some interesting posts, with good facts backing them... Rock on!
Old 06-21-2006 | 08:40 AM
ride5000's Avatar
Originally Posted by chimchimm5
All facts point to idle fuel level constantly being injected, even coasting downhill
MYTH BUSTED
if rpms > idle speed, and tps = 0, then idc = 0
i don't care what your scangauge says, my wideband tells me what's actually at the tailpipe.
Old 06-21-2006 | 10:08 AM
gijow's Avatar
Car Info: 2005 impreza rs
ride5000, care to define tps=0 and idc=0, so that we can all benifit from this information?
Old 06-21-2006 | 12:35 PM
ride5000's Avatar
tps = throttle position sensor, basically % of opening angle
idc = injector duty cycle, percentage of injector "on" time vs. total possible injector on time.
this closed throttle enleanment may also be validated with an egt sensor... find a very long downhill and you will see egts drop to temps far below idle egts. mine have dropped to ~400*F on occasion.
there is one caveat to the closed throttle enleanment conditions--if rpms are above the oem ecu's transition point from closed to open loop operation then fuel will continue to flow. this tends to hasten the cooling off of the chambers after hard driving. on my bugeye ecu this rpm point is ~5500 rpms.
Old 07-01-2006 | 07:19 PM
chimchimm5's Avatar
Hmmm... now I have to figure out how to consolodate this data. Apparently fuel is not burning...
So then why does the injector duty still show flow if EGT shows coolin? Maybe a "would be" duty?
SPEED ASSAULT
18
07-13-2012 01:15 AM
woocabin
07-02-2011 04:48 PM
trev0006
12-25-2007 01:41 AM
0260B4U
02-06-2004 06:12 PM
Quick Reply: More fuel efficient: Higher RPM less petal or lower RPM more petal?
